pirateslife
1969 Shasta Compact
Post by pirateslife on Apr 9, 2014 17:30:19 GMT -8
Made a simple angle iron battery holder today ( well got it cut out). If any one is interested, on a 1969 shasta compact. This will sit behind twin LP tanks. I used 1" x 1/8" angle iron. Used two 4 foot sticks. For series 27 battery boxes, like the Atwood boxes. 32 inches long x 7 1/2 in wide holds two boxes perfectly wit about an inch between the boxes I'm going to put a 1 inch flat bar in the center to be able to secure the lids to the holder. I'll post pics as soon as I get it on.
Post by vikx on Apr 9, 2014 21:56:38 GMT -8
Would you post some pictures, Pirate? Sounds good.
Post by bigbill on Apr 10, 2014 5:31:09 GMT -8
Are you going to have it so that the batteries can be locked in place to resist theft?
pirateslife
1969 Shasta Compact
Post by pirateslife on Apr 10, 2014 15:21:05 GMT -8
Are you going to have it so that the batteries can be locked in place to resist theft? I am..... Gonna do it one of two ways, after some tests by using some security nuts. Hope to get it all welded this weekend and get some pics.
pirateslife
1969 Shasta Compact
Post by pirateslife on Apr 24, 2014 16:41:08 GMT -8
pirateslife
1969 Shasta Compact
Post by pirateslife on Apr 24, 2014 16:44:17 GMT -8
For dual series 24 battery boxes , reduce the length to 27 " long x 7-1/2" wide
Post by John Palmer on Apr 24, 2014 17:34:09 GMT -8
Just curious, does the top hold down bar connect on the outside down to the base frame? Looks like you could just bend the 1/4" bar up, or twist it around the bolt, and remove the batteries.
Using a piece of 1/8" by 1 1/2" angle would make the top much stiffer.
Another thought would be to reverse the hold down bolt, and run the excess threads out the bottom for a cleaner look. Just weld the "thread-all" bolt to your hold down bracket. The last propane hold down I made, used a 3/8" black pipe for the hold down and I welded a 1/2" grade 8 bolt inside the pipe for the threaded portion.
pirateslife
1969 Shasta Compact
Post by pirateslife on Apr 24, 2014 17:39:10 GMT -8
The bends in the bar make it hard to get leverage on to bend up and having the inside bracket keeps it from "twisting off". They are tight to the lids which keep the spin factor down.... Thought about taking the 1/4" to the base of the frame and putting a padlock place but decided this should be enought to at least make someone consider moving to the neighbors trailer
Post by nccamper on Apr 24, 2014 20:18:10 GMT -8
My mother worked for the NY Court system for 20 years. She once told me, "Thieves are lazy, that's how they became thieves." Your set up looks secure enough to keep all but the most determined thieves away. Although my Mom also said, "In parts of New York City they can have the wheels off your car at a stop light while you're waiting for it to change to green." So don't camp in NYC and you'll be fine.
pathfinder3081
1971 Shasta Loflyte
Post by pathfinder3081 on Apr 25, 2014 6:34:51 GMT -8
I think that the "Deterrent" factors are being well met here. It looks secured and ready for the road too. Nothing is burglar proof. I am in agreement with "ya matta". NC' All you can do is slow them down and get'em to make some noise. A hefty set of bolts cutters or a torch can make short ones endeavors. I don't have good access to "counter sales" steel anymore, or the scrap bin either.. Bummer.. Looking good Pirate..
Post by SusieQ on Apr 25, 2014 8:27:34 GMT -8
I want to see it mounted to your frame.
pirateslife
1969 Shasta Compact
Post by pirateslife on Apr 25, 2014 13:46:42 GMT -8
I want to see it mounted to your frame. Me too... lol. itll prolly be a couple weeks my welder, i mean my uncle is goin on a cruise lucky thing All the steel came from the local HD
Post by vikx on Apr 26, 2014 22:01:38 GMT -8
Pirate, you might consider bolting it to the frame. Sometimes these handy things can get in the way of screwing the skin at the bottom, things like that. It would be a pain to unbolt it, but this week I wish I could've...
Post by John Palmer on Apr 27, 2014 4:11:03 GMT -8
Pirate, you might consider bolting it to the frame. Sometimes these handy things can get in the way of screwing the skin at the bottom, things like that. It would be a pain to unbolt it, but this week I wish I could've... Or "welded over" VIN#'s as I have found in a few cases.
