Flat-Tire
1965 Da-Vid
Post by Flat-Tire on Mar 25, 2014 18:28:03 GMT -8
I can paint fairly good; I've painted a few cars and a few bikes. I'll be using a single phase urethane in two color; white over turquoise. I feel it would be so much easier to paint the sides before their attached to the actual trailer; no tape, no mess. Two days later, install.
Does anyone see a danger sign here? Thanks
pirateslife
1969 Shasta Compact
Post by pirateslife on Mar 25, 2014 18:45:14 GMT -8
Are you fairly good at handling metal and cursing it and throwing it as far as you can without scratching it when it don't cooperate ? Lola little tape time is nothing to seeing your paint scratched. If it can go wrong it will. Especially if you are using old metal
Post by John Palmer on Mar 25, 2014 19:14:14 GMT -8
Don't paint the skin before it's installed. You will end up with many scratches.
New "Pre-Painted" aluminum is a totally different animal. The paint is "baked on", and is very durable almost like powder coating.
