yas
'63 Shasta Airflyte
Post by yas on Feb 14, 2014 6:30:43 GMT -8
Our new-to-us '63 AirFlyte has a broken outside door handle. Is this piece hard to get? I think I've found an old one on ebay, should I grab it immediately? outside door handle: inside door handle:
Post by schweetcruisers on Feb 14, 2014 7:02:35 GMT -8
Most of them are broken, so yes grab it or risk paying out the nose for a NOS one, if they're any still available.
Post by John Palmer on Feb 14, 2014 9:38:51 GMT -8
Yes they are out of production from my understanding. I have one on my 1958 Mallard than is working but should be replaced due to pitting. I believe there are a couple of different versions of the lock, so take it apart and make sure you find the correct replacement before you purchase.
Good Luck, and always save your old parts for future repairs.
Post by schweetcruisers on Feb 14, 2014 10:20:46 GMT -8
So your lock is a Bargman l-66, there is a early style that has a Art Deco looking handle and won't work unless you replace the whole lock. Your's is the more common one, it was made in the USA, but some where along the line in the 70's they shifted production to China. You can tell the Chinese locks apart by the screws that hold the internals together, the USA locks had little hex head screw(black in color) and the Chinese had Phillips head screws (silver in color). The handle might be the only thing that is interchangeable but I am not sure, a lot of the internals are just different enough that they're do not work.
yas
'63 Shasta Airflyte
Post by yas on Feb 14, 2014 10:57:07 GMT -8
Thanks!
I've done some more research, too. Agreed - it's an L-66 (not an L-66-1A). There are a couple on ebay, and a handle by itself. I was unable to find any NOS. I can't take my current one apart, as it's 900 miles from here.
So it seems I should start bidding! Maybe buy several :-)
Post by universalexports on Feb 14, 2014 13:38:31 GMT -8
not hard to get, there is usually a couple on ebay, the problem is the price is usally stupid high for a NOS on $250.00 and up, but if keep an eye out occasionally you can find a lot better deal on one. it jut takes a while sometimes.
Post by kirkadie on Feb 14, 2014 21:49:25 GMT -8
Pay close attention to the hole where the lock fits. Mine is round like yours. Scotty is missing the key. I bought what I thought was a replacement (with 2 keys) on fee-bay, but it has a notch or tang, and won't work. I am under the understanding that the handles, though, are interchangeable, and so might be easier to find. Someone speak up and correct me if I'm wrong.
Post by kirkadie on Feb 14, 2014 21:59:19 GMT -8
Door lock addendum; Just took another look at the picture of yours and it looks like it does have the notch. VTS has had that model in the past, and if they don't you can have mine since it won't fit my door. New old stock, 2 keys, and instructions on how to replace.
vic
Post by vic on Mar 31, 2014 9:32:01 GMT -8
I have a Shasta Compact with the same issue. I have been told I can use some garage door handles to replace this. Does it simply fit into the existing handle assembly? I should continue looking on Ebay etc I guess also. As long as I can fashion a plate to cover the hole, is a standard house type lockset advisable?? Thanks for all info.
Post by Ten on Mar 31, 2014 11:14:52 GMT -8
Vic-- I see by looking back to remind my feeble memory, that you have the "toaster" style of Compact. There were some made with the older "Canned-ham" latches, and then they switched to the L-66 (pictured above) sometime after the model changeover to the toaster... Is yous like the one above, or is it the "twist" type latch? The interior part looks sorta like this: The through-piece is nothing more than a piece of square stock, and the outer handle does resemble a garage-door handle. The outer handle and the complete kits are available here: teardroptrailerparts.com/Door_Handles__Latch_Kits.htmlOr here: www.vintagetrailersupply.com/Entrance_Doors_s/10.htmAnd of course on ebay, once you know what it is you are searching for.... Sometime in the course of its life, someone changed out the lockset on the Compact I just sold, and replaced it with a strom-door latchset. It is impossible to keep the door drawn tightly shut with it, as well as the fact that it cannot be locked. Although it may be possible to switch to a house set, I personally would recommend against it, especially since, if all you need is the outer handle, it can be replaced for less than the cost of a home lockset.
Post by kto17 on Mar 31, 2014 15:49:16 GMT -8
If you look around on the forum there is an exploded view of the L-66 posted. Don't know if that helps any.
Post by Ten on Mar 31, 2014 16:24:26 GMT -8
Post by vulcancowboy on Jul 3, 2014 4:01:35 GMT -8
Has anyone come up with an economical replacement for the L66? It doesn't need to look original, just functional. I don't want to pay what I see them selling for on eBay.
colagirl
Post by colagirl on Jul 8, 2014 13:54:26 GMT -8
We just bought Shasta #2 and the handle is broke on it. That's not the bad news, when I took it apart every moving part in it was missing. I got a latch bolt from VTS but that's all they had .I had to take the latch off of Shasta#1 ,open it up and see what parts were missing, then I spent an entire day in my shop fabricating parts. works great but handle still broken.
pathfinder3081
1971 Shasta Loflyte
Post by pathfinder3081 on Jul 8, 2014 15:56:44 GMT -8
Anyone in the search.. You need to look on EBAY today.. There is one guy with a lock.. Crazy price for me, I don't lock anymore.. Then.. there was the other ad.. I saw a L66 rig for $50 +/-.. I am thinking about getting it myself for the "just in case" thingy.....
