vociferous
Post by vociferous on Apr 30, 2024 9:07:56 GMT -8
My 16ft 1960 B&B Cozy Home needs a paint job. I'm actually thinking of selling and I figure I'll get a better price if she looks nicer. But even if I keep her, it's time.
The first bid I got for painting was about 50% more than the value of the entire trailer---are there any options other than DIY if a 15K$ paint job is just something I can't bite the bullet on?
Post by John Palmer on Apr 30, 2024 9:47:09 GMT -8
The $15K estimate is just another way of someone saying, "I do not want to do it".
Post by Hamlet on Apr 30, 2024 14:09:55 GMT -8
The $15K estimate is just another way of someone saying, "I do not want to do it". John Palmer Aah, John Palmer is wise. We dealt with the same thing when we had to pain Hamlet more than a decade ago. We wound up taking him to the repair folks at Camping World. It was reasonable, considering his box is only ten feet long, but they did a wonderful job and were so excited to do a true vintage trailer, that when I went to pick him up one quiet morning, everyone in the shop and half the folks in the store came out to wave goodbye. Keep looking and good luck!
Post by John Palmer on Apr 30, 2024 21:29:55 GMT -8
So........if your looking for a professional paint shop to paint your vehicle they are not going to use anything but quality materials because they cannot afford to have a failure and you be unhappy with the finished job. There's too much gamble involved in labor cost to use cheap materials.
So.......lets consider some numbers. Sandpaper costs me $40/roll for PSA 320, and another $40 for a roll of PSA 400 grit, masking tape is now $20/roll x5, masking paper and plastic drape for over spray, a gallon of automotive UV quality paint, plus activator, plus reducer is an easy $400., you need at least a two part primer for the aluminum, that's $200 (I paid $350 for the last gallon kit I bought three months ago which is a gallon part "A" plus two quarts of part "B"). You not going to have it painted only one color, so you need a quart more ($100.) of a trim color, and more 3M plastic FineLine tape at $20/roll to tape out the graphics. Acetone to clean out your spray gun is $20/gallon. A sign painter is $200 to hand paint the lettering on. Let's just call it $1000 is the absolute minimum cost in materials to do a nice long lasting paint job with quality materials in today's world.
I have painted my own cars/trucks/bronco's/trailers and it's a lot of work. The high cost of painting a trailer is in the time necessary to do the prep work. You need to remove all of the metal trims, the windows, remove all of the putty and gunk. Sanding a trailer with a siding brake pattern is going to require lots of hand sanding after you have exhausted every possibility of machine sanding.
Where are you going to spray it? I have done several in my driveway under a 10 by 10 E-Z-Up with walls. I just tape it off and spray one side in the morning, let it set up, flip the trailer around and paint the other side in the afternoon. The next day, I shoot the front in the morning, and the back in the afternoon. I then tape off the graphic's and repeat the above schedule the next two days painting the second color graphic trim.
I have never found a professional shop paint job for less than $2K, "Plus Materials", which puts the cost at $3K. and YOU DO THE HEAVY WORK. Keep in mind that when I take a trailer to be painted, it's fully sanded, prep'd, graphic's are already taped off, etc. They just put it into the booth, cover the wheels, wipe it down, and shoot. I bring it to them 80% done. I have two different friends that had Breadloft Trailers that were painted during the last year and they were both over $7K.
After you get it back, you will still need to straighten and install the windows, the eyebrows, clean or install new rain rails and awning rail etc. It's an easy 200 hours of labor, or more.
In today's body shop world of high labor costs, very few body shops will even accept a "full paint job" on a car. It takes too much time that they could be doing more profitable insurance collusion work. You need to look for a small shop, or someone that is a body painter and works weekends on the side.
Unless the vintage trailer is a fully restored, a popular year and body model, it's seldom financially worth getting it repainted.
Just my observation.
