pirateslife
1969 Shasta Compact
Post by pirateslife on Jan 30, 2014 15:03:57 GMT -8
Well since its too cold to go work on it tonight, i'm sittin around "plannin" . I was readin in the brochure section that brake flanges were standard on the second gen compacts. does this mean they all should have the backing plate? I would just go look but ive got it all leveled up and cant get under it for a week or two. thanks guys and gals
Post by bigbill on Jan 30, 2014 15:45:22 GMT -8
The flange is the part of the axle that the backing plate bolts to. If yours doesn't have brakes then the complete brake package should just bolt on if you you have flanges. When you look if you see backing plates you have brakes, they may or may not work but they are there if you see backing plates.
pirateslife
1969 Shasta Compact
Post by pirateslife on Jan 30, 2014 15:55:18 GMT -8
that helps, i was thinking the flange was the backing plate. only had the wheel of once to put a spare on to get it home and didnt think to look. thanks
Post by Hamlet on Jan 31, 2014 20:34:23 GMT -8
Well since its too cold to go work on it tonight, i'm sittin around "plannin" . I was readin in the brochure section that brake flanges were standard on the second gen compacts. does this mean they all should have the backing plate? I would just go look but ive got it all leveled up and cant get under it for a week or two. thanks guys and gals Which would explain why Hamlet doesn't have brakes... DUH!!!
