newin62
1962 Shasta Airflyte
Post by newin62 on Feb 13, 2024 7:16:05 GMT -8
A little bit of contrast between the cabinet doors and the face frame isn't necessarily a bad thing. In fact it's a typical look in many vintage trailers. That being said, I think that aesthetically you can't really go wrong by copying whatever the original manufacturer did.
jester76
1954 Aljoa sportsman
Post by jester76 on Feb 13, 2024 18:53:49 GMT -8
Thank you. When I put the skin on the frame, I cut the skin slightly larger than the width of the frame, then glued and clamped it all down, then used a router with a very small roundover or flush cut bit to trim off the excess, and im sure you know that those veneers are so thin that sanding even just a little can go right thru the birch layer, like micro micro mm thin
Post by 1963astavillastamped on Feb 14, 2024 17:37:08 GMT -8
A little bit of contrast between the cabinet doors and the face frame isn't necessarily a bad thing. In fact it's a typical look in many vintage trailers. That being said, I think that aesthetically you can't really go wrong by copying whatever the original manufacturer did. Hello again newin62, Valid point. The original seems to be pine with a kind of stain meant to mimic amber shellac. Unlike present company (serious restorers), I am not interested in going to extreme lengths for authenticity :-). BUT, I would be wise to first test the finish on 1x2 pine to see how closely it matches/doesn't match the birch plywood. I will save a step if I don't laminate and it will be easier to make corners. Before we "measure twice, cut once" we make plans ten times over :-)
Post by 1963astavillastamped on Feb 14, 2024 17:43:02 GMT -8
Thank you. When I put the skin on the frame, I cut the skin slightly larger than the width of the frame, then glued and clamped it all down, then used a router with a very small roundover or flush cut bit to trim off the excess That makes sense. Must be quite satisfying to zip off the excess.
Post by 1963astavillastamped on Mar 4, 2024 17:22:08 GMT -8
Instead of amber shellac, I decided to use Rubio Monocoat for the interior. It is a colour called "Mist". This week I finally got around to testing the finish in both white pine and birch. Good news - they're a very close match. Unless you look very closely you can't see the difference. That means I can go ahead with pine for the face frame, which should be less work overall!
Post by Teachndad on Mar 5, 2024 6:08:49 GMT -8
If we are all looking to see if there are shade differences in the wood, I can't see them. Once inside the trailer with the muted lighting coming in from different angles, no one would notice an almost imperceptible difference.
I am looking forward to seeing how the Rubio Monocoat works out for the overall look and application.
Cheers,
