newin62
1962 Shasta Airflyte
Post by newin62 on Nov 7, 2023 4:05:33 GMT -8
I was planning to add an accumulator tank to my water system and ordered one on line. My problem is I'm running out of room and I'm having a hard time trying to figure out where to mount it without fabricating some kind of fancy bracket and running water lines that will be hard to drain. I had to put the pump on the floor under the kitchen counter because the space under the dinette bench is already packed full with the water tank and electrical stuff. The area under my sink is also packed full because of the water heater. I don't recall reading about anyone's experience with these and Im now wondering if I should bother with the tank at all. Any thoughts on these?
Post by vikx on Nov 7, 2023 13:13:51 GMT -8
Some folks add accumulators in modern RVs to keep the pump from cycling so often. Many mid range trailers don't come with accumulators.
Most of our vintage trailers have a simple cold water system with only one faucet. I would try your system before installing one. If the pump doesn't bother you, it may not be needed.
newin62
Post by newin62 on Nov 9, 2023 2:44:13 GMT -8
It's been a long time since I used my camper but I do remember the pump didn't like it at all when the faucet was only open a little. We were sucking water straight out of then lake back then so we just let the water flow. Now with only 18 gallons on board I'm thinking more about conservation. I have been reading on various forums that people who install accumulators really like them as they smooth out the low flow pump cycling issues. Since I already bought mine I think I will revisit my plumbing layout to see if I can fit this in somehow.
Post by vikx on Nov 9, 2023 13:55:23 GMT -8
You might be able to hang it on the side of the cabinet?
