Post by countrybuc on Sept 4, 2023 12:13:40 GMT -8
Post by vikx on Sept 5, 2023 11:30:23 GMT -8
Welcome Countrybuc.
Photos would help us help you.
Post by countrybuc on Sept 6, 2023 17:32:01 GMT -8
Thank you. I'm trying to post photos but don't know how. lol
Post by Teachndad on Sept 7, 2023 4:16:22 GMT -8
Post by countrybuc on Sept 12, 2023 20:34:00 GMT -8
Post by Teachndad on Sept 13, 2023 4:58:46 GMT -8
Hi,
I have posted the photos to help you out. We will need to see photos of the interior. Kind of curious how Godzilla got inside and escaped through the top.
Here are some tips for posting pix. In Flickr, click on the bloated arrow in the lower right hand corner of your screen, then you can then click on the BBC code. Copy and paste that directly into the text of your post here at VTT and the image can show up. Then, click on the Create Post button in the lower right corner of your screen and then the image will show up.
Also, here is more on photos from Vikx: LOGIN to Flickr and click on the bloated arrow of the photo as Rod said. It will take you to a box. Click on "embed", then copy the URL. It will turn blue when you click on it. Paste into your post on VTT and the photo should show up.
As to the ages of the trailer, this trailer has a mix of indicators for age all wrapped up into one almost like what I would call "a Frankenstein trailer". It's got high marker lights if original would indicate 1968 or later, larger front jalousie windows introduced @ mid 60's with small pane jalousie windows on the sides which where common late 50's to mid 60's. Then there are the teardrop shaped wheel well cut outs. That's an early to late 50's motif. The brakes in the aluminum siding indicate 60's.
Let's see what others say.
Cheers,
Post by countrybuc on Sept 21, 2023 18:40:26 GMT -8
Thank you Rod. The inside is there but is pretty damaged from I believe a tree fell on it. I started removing the skin. I found the 12v wiring was cotten woven wire. I will try to post photos of inside soon.
