kedd
Post by kedd on Aug 10, 2023 11:29:58 GMT -8
How would I find a manual on a 1984 Shasta 2100 travel trailer? I have looked all over. Tia.
Post by vikx on Aug 10, 2023 12:33:32 GMT -8
Most trailers did not have a "manual". There were brochures on axles, brakes, appliances, etc. separately. This is true of vintage trailers and also modern new trailers.
Airstreams came with a manual and possibly a few higher end trailers. Holiday Rambler? Avion?
kedd
Post by kedd on Aug 10, 2023 13:41:12 GMT -8
How would I find anything out about the plumbing?
Post by weekendwanderer on Aug 10, 2023 13:58:05 GMT -8
Hello I have a 85 Shasta Friendship 17. The plumbing is pretty basic, it is grey pex tubing. The main inlet is from the street side hookup, from there it branches off to the water tank then starts a continual loop around the trailer. You used to be able to go to the Forest River website and download older owners manuals. I just went to the site and can’t seem to find the link. I have the 1985 manual downloaded but I am unsure how to link an attachment to this post
kedd
Post by kedd on Aug 10, 2023 15:31:03 GMT -8
Weekendwanderer could you send it in a email?
Post by vikx on Aug 10, 2023 16:48:10 GMT -8
As said, the plumbing is pretty much visible and easy to fix. Nowadays, most builders use Pex. Always replace all copper water lines. (they tend to swell over the years and new fittings won't work)
Post by nccamper on Aug 11, 2023 16:13:31 GMT -8
