hotrodjim
Post by hotrodjim on Jul 31, 2023 2:52:29 GMT -8
Hello!
I’m replacing our stove/range in our camper with a Holiday stove.
I understand that the range rest on top of the counter top and the face frame work. It also sits on a platform
But how do you secure it from moving around.
There two very small holes on top in the back of the range trim, But these are the size of very small brad hole. Is this the only thing holding the stove from moving around.
How do you secure it.
Thanks All Jim.
newin62
1962 Shasta Airflyte
Post by newin62 on Jul 31, 2023 5:11:32 GMT -8
My Holiday stove is the freestanding type without the trim around the top and sides so Im not sure if this applies to your model. It was mounted to the bottom support with #8 fine thread wood screws through two holes in the bottom of the oven, approximately two inches back from the oven door.
hotrodjim
Post by hotrodjim on Jul 31, 2023 13:41:09 GMT -8
Thanks, I found it.
had taped shut the stove door not realizing that it was directly over the screw hole.
