idaho211
Post by idaho211 on Jul 1, 2023 5:20:48 GMT -8
I have a 1958 Shasta with the original Atwood screw jack. The one with the tear drop tube. It was becoming harder to operate so I decided to do some maintenance on it. I filed down the mushroom end of the pin that holds the handle.and the assembly came out. I had to take a punch and hammer to remove the pin due to rust. After that the whole assembly came out. It has a thrust bearing at the top of the worm( two big washers with grooves with 1/4” ball bearings sandwiched in between. I cleaned the bearing surfaces of the washers and long worm and bought new ball bearings. Only place I could find the ball bearings was the bicycle shop. 1/4” bearings are common for bike hubs. I applied grease to one bearing surface of the washer then added the bearings then sandwiched the other washer with grease on top of the bearings. This held everything in place when I reinstalled the assembly. I coated the worm with a good NLG2 grease. Re-assembly was easy, carefully reinstall the screw worm with the thrust bearing sleeve at top and bearing sleeve, handle with new 1/4” inch bolt and nylock nut. I sprayed the sleeve bearing surface at top with a thin lubricant to prevent binding.
I reinstalled the 4 nuts on the tongue.
What a difference it makes with smooth operation and less binding. It will be easy to re-grease by now just removing the bolt by the handle.
Hope this helps.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Jul 1, 2023 5:37:27 GMT -8
Thanks Idaho! Did you do step by step photos by chance? Would make a good tutorial.
Just a thought, didn't say it was a good one... Whitney
idaho211
Post by idaho211 on Jul 1, 2023 8:08:00 GMT -8
As I was making this thread I was wondering why I didn’t take any pics. I guess it was in the heat of battle.
I will take some next time.
Post by Teachndad on Jul 1, 2023 17:34:41 GMT -8
Nicely Done! You do have a detailed description and that helps a lot! Thanks for sharing this.
I was waiting to see you mention worn parts, but fortunately, it sounds like they just all needed a good cleaning and a lube.
Cheers,
idaho211
Post by idaho211 on Jul 1, 2023 20:48:17 GMT -8
Rod,
The worst wear were the ball bearings which were pitted while the bearing surface on the washers were less pitted and I was able to use 0000 steel wool to smooth them up. The thrust bearing assembly was completely dry and I was surprised it wasn’t worn more.
The worm screw wasn’t really worn but just dry with no grease. I used a brush to clean the dirt and grime off and applied NLG2 Grease ( I used Lubriplate 1242 grease.
It is a pretty simple mechanism.
The hardest part was removing that pin from the handle due to corrosion.
Post by nccamper on Jul 2, 2023 17:45:29 GMT -8
I agree with WhitneyK, it would make an excellent tutorial
chriss
Post by chriss on Jul 5, 2023 18:23:31 GMT -8
Handy tip: use 2-4-C marine grease on the bearing and screw assembly. It will last for awhile and repel water.
idaho211
Post by idaho211 on Jul 6, 2023 5:17:38 GMT -8
Good idea Chris
