joe12
Post by joe12 on May 22, 2023 18:05:39 GMT -8
Greetings and thanks in advance for your help.
My camper is a 2008 Scottie Like Object, made in Ohio I believe by the people who are now making T@b campers. The back has rotted considerably and with the advice of Larry from Mobiltec I am restoring it. I need to purchase a white plastic covering for the corner channel that is at the edges of the camper. Where is the best place to buy this?
Also, do you have any idea how to remove the stains on the aluminum that are under the windows?
I tried to add pictures but I do not know how to insert them from my Mac computer.
Thanks again, Joe
Post by Teachndad on May 22, 2023 19:28:44 GMT -8
joe12
Post by joe12 on May 27, 2023 5:33:03 GMT -8
joe12
Post by joe12 on May 27, 2023 5:34:17 GMT -8
joe12
Post by joe12 on May 27, 2023 5:39:54 GMT -8
Here are two pictures of the camper that I finally found out how to upload. I did find that I could purchase the white plastic channel from where else but Amazon.
I would appreciate advice on how to remove the stains that are on the aluminum under the windows. Regular cleaners and elbow grease do not seem to help.
Thanks, Joe
Post by vikx on May 27, 2023 10:15:34 GMT -8
Have you tried No. 7 White Polishing Compound? That might reduce the stains. Another cleaner that might help is Oil Eater Cleaner/Degreaser.
joe12
Post by joe12 on May 28, 2023 5:17:52 GMT -8
Thanks for the information. I heard from Larry that the paint has actually changed color over time and the stains will not come out and that it would need to be repainted. : - )
Post by mobiltec on May 29, 2023 5:55:49 GMT -8
Thanks for the information. I heard from Larry that the paint has actually changed color over time and the stains will not come out and that it would need to be repainted. : - ) That was just a possibility. Go ahead and try the stuff that they mentioned out.
