Post by robcaleb36 on Feb 5, 2023 10:04:39 GMT -8
So, turns out every LED lights needs to be grounded. This is easy for brake lights, since you should be running, at a minimum, flat 4 wire harness. However, I'm running into a small hurtle; Grounding rhe new marker lights. I'm replacing the old, shot, incandescent marker lights with waterproof LED. Normally one would use a wiring fish and feed that through, however, good luck on finding an easy route with that, LOL! Anyone have any 1962 Shasta Compact wiring or skeleton (framing) diagrams, or effective ideas?
Post by vikx on Feb 5, 2023 12:04:22 GMT -8
You can add a small grounding wire to each section of skin. Go thru a bottom skin screw to the frame. The skin will then be effectively grounded and the light screws should ground the light.
Grounding is easy when the skins are off. You should remove at least the bottom skins to check for rot in any case. That will give you an easy way to run the ground wires.
chriss
Post by chriss on Feb 7, 2023 11:36:16 GMT -8
I ran a small pigtail from the marker light to a sheetmetal screw through the skin and covered by the light housing. Working good for me. The skin has ground connections in 2 spots leading to main ground wire.
