Post by vikx on Dec 28, 2022 11:48:37 GMT -8
Welcome! Holiday Ramblers were well made trailers so the bones in this one may be good. Lifting the skins will tell you a lot.
I suggest a metal roof replacement because of the weight and short life of a rubber roof. New rubber roofs are guaranteed for only 12 years IF you do the maintenance... they are normally installed over 1/8 Luan plywood with a special glue.
Metal roofs can be bought in any length and/or you can check truck semi repair companies. Take some time and do lots of research.
Post by Teachndad on Dec 30, 2022 8:22:45 GMT -8
Hello and Welcome!
That's going to be a BIG project. Big trailers offer more work, LOL. As Vix posted, you will have to remove the skins. I can tell you the rear is going to be in sad shape. The PO covered that back wall for a reason. Usually, that marks water damage underneath. That right rear corner patch is an indicator of problems below. The opposite corner has the J-rail disconnected so, water got in there and rotted out the screw holes so now there is no "purchase" for the screws.
Post by nccamper on Dec 30, 2022 19:44:35 GMT -8
Welcome!
It reminds me of our family camper when I was a child.
