gmckean
Post by gmckean on Dec 13, 2022 18:32:17 GMT -8
Hello all I was given a 1950 (I think) Avalon. I haven't even touched it yet because before I dive it to it I need to learn. Even the basics elude me. The placard on the trailer says "Avalon Trailer Company" Serial:50414 Type:M15 What does any of that mean? I saw another member with the exact same everything on her trailer except "50417 M15" I can find almost nothing on an Avalon trailer (of any year), is it because it's rare or basically a trailer I need to avoid?
I have a ton of questions but just deciding if I want it is my first step. Any help would be appreciated, I'd like to image I could built/restore something I'd be proud of. Thank you GM
Post by nccamper on Dec 14, 2022 0:02:51 GMT -8
Welcome!
There were a lot of small manufacturers that each did things differently with vin/id numbers. Hopefully somebody with an early 50s Avalon will chime in.
Along with info you'll find here there are two resources from our members you should check out: Some excellent videos at cannedhamtrailers.com And a great book at vintagetrailerrepairmanual.weebly.com/
Learning before starting is a wise move.
Post by vikx on Dec 15, 2022 12:53:50 GMT -8
Welcome. "50###" is a serial number. The 50 may or may not be the year. M15 is probably model 15=15 feet total length. If the trailer has real wood paneling inside, it is likely to be 1963 or older.
I did a quick search for Avalon vintage trailers and they seem to be rather typical 60s type trailers. If there are upper clearance lights in the front and rear, the trailer is newer than 1068. Beware larger trailers, especially with dual axels. They really are beyond "vintage" and not in demand like the shorter (and lighter) canned hams.
I agree, do your research and learn what is ahead before buying. You will need covered storage to do the work and it can take as long as 8 months or more.
Post by Teachndad on Dec 17, 2022 7:24:21 GMT -8
Hi and Welcome,
Does it look like the model pictured in threads posted by member erica b, another Avalon trailer owner? I see you have posted in one of them.
For us to help you as much as possible, please post some pix of your trailer both exterior and especially interior including walls and ceiling? Here is a link to a tutorial on posting pix. vintagetrailertalk.freeforums.net/thread/7276/add-photos-hosted-flickr-tutoria
As to your question regarding the lack of information on an Avalon and it's quality, I doubt quality had much to do with it's present rarity. As NCCamper pointed out that there were a lot of small manufacturers back in the day and it really wasn't so much quality of build, but where the trailer ended up for decades - under a tree, in an open field or under some structure. West Coast or East Coast.
Cheers,
