ruderunner
Post by ruderunner on Apr 3, 2022 2:15:49 GMT -8
Regarding dum dum or better known as rope caulk, is it the same material as putty tape?
I recently used some when replacing a broken window and it crossed my mind that it might be.
Post by vikx on Apr 3, 2022 11:14:37 GMT -8
I think it's similar but harder to use since it's much narrower. If I remember correctly, it may be more oily than putty? Should work just fine.
Post by Teachndad on Apr 5, 2022 21:56:02 GMT -8
The surface(s) you use it with should be really clean. Fresh stuff works better than stuff that's been on the shelf for a while.
