0rr84
Post by 0rr84 on Apr 1, 2022 14:43:07 GMT -8
Hey everyone,
I've taken a video and posted it on youtube... I'm a visual guy so I thought I would tape it instead of write it all out...
Post by vikx on Apr 1, 2022 16:35:41 GMT -8
The video helped but we need to see more. Maybe take some stills a little further back so we can see exactly where the wires terminate? By the opposite wheel well or? Is the switch by the door? Please post a photo of the porch light and bulb.
First of all, by code, AC and DC should never be in the same junction box. I'm guessing that the switch was possibly used to cut the DC power to save battery power? The ceiling light appears to be 12 volt, rather than 110. You said the switch is powered now by 110? (sorry can't check the facts in the video)
There are multiple uses the DC wires could have. A water pump, coming out of a converter, lighting, etc.
chriss
Post by chriss on Apr 2, 2022 6:37:28 GMT -8
I would have guessed the toggle switch was to a water pump if it's near a sink. It's possible there was never any 12v accessories originally in your trailer and all that stuff was added. That ceiling light looks like an owner add-on.
I would have to see what's in that junction box. Maybe it did feed 120v to a converter that's no longer there.
0rr84
Post by 0rr84 on Apr 2, 2022 8:57:38 GMT -8
Hi guys,
Thanks for your feedback. I've taken some photos and I'll try to get them up soon. In the meantime, here is what I've determined to be fact:
When I place the 110 probe on the rear side of the switch(inside cabinet), it lights up whether the switch is up down or off... the probe does turn off when I am physically holding on to the toggle switch... am I the ground?!
The grey line that runs from the junction box through the ceiling and down the closet, under the camper to the step/porch light is a 12v bulb. The step light is cylindrical and I haven't been able to find a replica online (and I have some pretty nerdy google skills lol) which leads me to believe its unobtanium.
The brown wire from the junction box runs through the ceiling and down in to the closet and currently is connected to nothing.
The switched 12v light seen briefly in the ceiling, also runs down the closet and is spliced in with the Brown line mentioned previously.
I have scoured the trailer, head to toe, nook and cranny... and I cannot see any evidence of other jerry rigged electronics, there is no indication that an inverter or converter once lived anywhere so I just can't figure out how these 12v accessories were powered...
I guess it was as simple as throwing a battery in the closet? If so, what was the purpose of having a switch differentiating 110 and 12v?
I guess the next thing to do would be taking the junction box cover off and take a picture of that?
Thanks for your attention to this and helping me solve this riddle!
0rr84
Post by 0rr84 on Apr 2, 2022 10:52:03 GMT -8
I think my cinematography is improving
Post by vikx on Apr 2, 2022 12:18:52 GMT -8
Still photos would help us. Videos move and don't allow us to study exact connections, etc.
This sounds like a mess to me and not safe.
The best course would be to remove the box, transformer and switch. After disconnecting all power to the trailer, snip the wires as long as possible and leave them in place. They can be re-purposed as you move along. Wrap the ends of each wire or use an electrical wing nut to prevent accidental shorts when power is reconnected.
Using a multimeter, test the wires coming out of the grey sheathing to see if they are "hot" when the trailer is powered up. The meter should read in the 118 to 125 range when on AC. Whichever wires are hot should be labeled as 110 in. See if you can trace these wires to the source of power. It may be the grey cable or other wires.
Do some more testing to see what still works in the trailer. List working lights, outlets and appliances. Obviously the porch and step light won't be operating. My guess is that the switch may have been for the step but from your description, things are not wired properly.
I enjoy sleuthing out electrical. Please answer a few questions:
Where is the switch located? Does the grey cable enter another J box somewhere? I'm guessing the 12 volt wires were connected to a battery in the closet. Any marks at all on the floor?
Your trailer can have a safe 12 volt system added. The solution is to start over and get it right.
0rr84
Post by 0rr84 on Apr 2, 2022 12:40:42 GMT -8
I enjoy sleuthing out electrical. Please answer a few questions: Where is the switch located? Opening the door, the toggle switch is located immediately to the left once inside... conversely, it is on the open face of the cabinets above the dinette.linkDoes the grey cable enter another J box somewhere? No the grey cable comes out of the junction box past the ceiling, to the closet, down, under the camper, straight to the step light. Inside CabinetI'm guessing the 12 volt wires were connected to a battery in the closet. Any marks at all on the floor? None, which is the strangest thing. Just as an aside, the trailer has an original bergman female 30amp outlet on the outside, paired with a 30amp fuse block, with two 15amp glass fuses. This serves one outlet, two front reading lamps over the goucho section, a lamp over the kitchen, a lamp over the dinette and the Fridge. So I have accounted for all of the Shore power stuff. Its the 12v systems (which as far as I can tell) was an attempt at the 12v ceiling lamp, step light and a cigarette/charger of which I have removed. It all comes down to this switch which I will now take a picture of. Thanks again!
0rr84
Post by 0rr84 on Apr 2, 2022 14:22:37 GMT -8
*UPDATE* As I putter around this thing, I found an old golf battery and hooked it up to the black leads at the bottom of the closet.
The black lead follows upwards and splits off to to the 12v ceiling lamp and the switch we've been talking about... well, the 12v lamp works just fine AND when I toggle the switch to 12v, the step light turns on. It would seem to me, that these guys just wanted to be able to turn the step light on using shore power or 12v...?
Fire extinguisher and rubber gloves in hand, I'm going to plug in the trailer and see if this is, in fact, just a vintage 110 converter.
0rr84
Post by 0rr84 on Apr 2, 2022 17:05:10 GMT -8
*UPDATE V2*
So it would appear, everything works as it was intended.
After hooking up the battery, (rebuilding the step light with new wiring and connectors)... the switch is wired to work for the step light in 12v format and 110... thanks for everyones input!
chriss
Post by chriss on Apr 3, 2022 0:21:46 GMT -8
I didn't see the transformer in the first video. That's a doorbell transformer, and somebody definitely homebrewed that setup. Looks like a toggle switch with "ON OFF ON" so they can use either the transformer when plugged in to shore power or a 12v battery if boondocking.
Problems I see is 110v and 12v mixed in same box and no fusing for 12v. Also, not sure if those bell transformers are designed for continuous duty.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Apr 3, 2022 5:10:35 GMT -8
I didn't see the transformer in the first video. That's a doorbell transformer, and somebody definitely homebrewed that setup. Looks like a toggle switch with "ON OFF ON" so they can use either the transformer when plugged in to shore power or a 12v battery if boondocking. Problems I see is 110v and 12v mixed in same box and no fusing for 12v. Also, not sure if those bell transformers are designed for continuous duty. I agree with Chriss. I thought the same thing about the door bell transformers, but then got to thinking about it.... They (db trans) do operate constant so they can keep the light in the DB button lit. Maybe I missed this, but the gray wire in the closet, did you confirm that it is connected to the 12v switch or just assuming since it is the same color? Since everything works as it should, if you really wanted to know where everything went you would need to disconnect each wire and using the continuity setting on the multi-meter, track them down to the other end. Just a thought, didn't say it was a good one... Whitney
0rr84
Post by 0rr84 on Apr 3, 2022 7:36:02 GMT -8
Thanks Chriss and Whitney, the riddle of the transformer has been solved. Doorbell transformer... you have to take a moment to appreciate someones cleverness.
Few questions to answer: The grey line is definitely the same line that leads from the switch/junction box to the step light. I replaced a ceiling panel and with it off, I can confirm it was the only line... the ceiling is the only part where it is concealed as it runs down the closet, through the floor and wraps around the undercarriage frame to the step light.
Both of you are correct in that I do not have a fuse block set up for the 12v systems. I just set up a quick small battery to test so since I have confirmed their functions, I'll be cleaning up the actual wiring and creating a cleaner, easier to access, fuse panel. (I'm currently building my solar off grid setup so this will have to wait)
As far as the wiring, it is pretty janky. The toggle switch shows a rating of 125v stamped in... so as homebrew as this was, seems he/she put in components that won't melt and set fire. I will definitely be separating the 110v and 12v leads in to two separate boxes... 110 in a junction box and I will probably solder and heat shrink the 12v stuff.
I hear you about the continuity bit but I would think that since our doorbells are hardwired 110 it should be ok.
Really appreciate your input!!
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Apr 3, 2022 13:52:22 GMT -8
I hear you about the continuity bit but I would think that since our doorbells are hardwired 110 it should be ok. Really appreciate your input!! Yes, and since it was only running 2 lights..... That's what we're all here for. Whitney
Post by nccamper on Apr 6, 2022 5:26:15 GMT -8
Interesting thread. the videos are a nice touch.
