Post by Teachndad on Jan 8, 2022 10:48:04 GMT -8
Hi Friends,
I had to make an urgent repair to my Rod and Reel entry door. Currently it's off the hinge and on a patio table waiting for disassembly. I can see through the Bargman door lock opening that the inner wood supports are 1" thick. Add the paneling and the total door thickness is 1 1/8". If my research is correct (correct me if I am wrong), then actual 1" thick lumber is not made any more. You either have to plane it down (I don't own a planer or have the space for it) or I buy actual 3/4 thick lumber (if available) and then make it thicker by adding 1/8" paneling strips on top of it as a spacer. I imagine these would have to be glued.
Any suggestions/opinions for lumber or method?
Thanks
Post by vikx on Jan 8, 2022 11:19:25 GMT -8
"Rip" a 2 x 4 to the desired size. I use a table saw for exactly straight cuts but a skill type saw works very well. Mark a line and follow it. A test cut will allow you to know where the blade cuts.
If you are working alone, clamp the wood before cutting.
Post by brandon428 on Jan 9, 2022 10:06:03 GMT -8
Vikxs' advice is on the money, however, if you need a piece that's real 1" x 3-1/2" and are going the skil type saw route, I'd suggest starting with a 4x4. Ripping a 1" slice out of that is much easier as the 4x is more stable when clamped.
Post by wisconsinjoe on Jan 16, 2022 10:45:14 GMT -8
This might be a good excuse to buy a portable thickness planer. It will allow you to dimension any wood to the exact thickness. Of course, a good table saw, used SAFELY with hold-downs to keep it close to the fence for accuracy and to avoid kickback, can do a good job.
adderall
Post by adderall on Jan 23, 2022 15:47:03 GMT -8
FWIW if you're in WI, find a Menards. They'll usually rip and cut dimensional lumber down to whatever you need at no cost. I ended up buying a table saw because in the end, it was more cost effective and I could fab what I needed without an hour lost to driving time, and money lost to me wandering the tool section and buying things I didn't need.
Post by nccamper on Jan 24, 2022 5:52:13 GMT -8
This might be a good excuse to buy a portable thickness planer. I use it Dewalt thickness planer in Haiti. It was a great tool. I just don’t have the space for one at the moment
