halljohns
Post by halljohns on Jan 3, 2022 5:34:09 GMT -8
Does anyone have a suggestion on the best stain to use on the inside of my Shasta. I am trying to match what is not being replaced (original)? Looking of a brand / tint / color or another suggestion. Thanks in advance for any advice.
Post by nccamper on Jan 3, 2022 5:46:11 GMT -8
Time and exposure to sun and elements change the tint/color. Just take light or mirror off and you’ll see what I mean.
With that said, I’m assuming your Shasta had amber shellac on it originally. Some early 60s campers had a milky color when new which is difficult to match. Can you attach photos of your camper to this post? It will help us answer your question.
Post by vikx on Jan 3, 2022 11:40:29 GMT -8
It also may be clear shellac or a poly finish. I don't believe either had a "color" but the golden color comes with aging...
Amber shellac works well to blend the old with the new. One fresh coat on the old and 3 on the new...
Post by nccamper on Jan 3, 2022 15:40:47 GMT -8
Sorry but how do I copy a picture into this string? You’ll find tutorials showing how to link photos to your post here: vintagetrailertalk.freeforums.net/thread/7276/add-photos-hosted-flickr-tutorial
halljohns
Post by halljohns on Jan 4, 2022 7:53:07 GMT -8
Post by vikx on Jan 4, 2022 12:10:28 GMT -8
I would go with amber shellac as said above. It will blend the panels very well. You did good on the photos!
Post by nccamper on Jan 4, 2022 15:43:06 GMT -8
I also vote for amber shellac. Maybe a couple of coats. The top coat of clear may not be needed. You’ll have to experiment.
cozwurth
Post by cozwurth on Jan 7, 2022 16:27:51 GMT -8
I'll suggest Amber Shellac, too. When I was building my Rancho I ended up with two different types of paneling because I didn't buy it all at one time. I was able to match the color/tone of the two different panels with amber shellac. I had my side walls done and had to match the front/back/ceiling to them. I took scraps of the panel and started applying coats until I got a good match. I wrote the number of coats on the other end so I could keep track of the number I applied. You may have to mix in a little clear to lighten it up some to match, but that shouldn't bee too bad. Edit to add a picture: DSC00587 by cozwurth, on Flickr If I remember correctly, the front wall (left side in pic) has 5 coats of amber shellac, and the side walls have 3 coats.
Post by nccamper on Jan 7, 2022 20:38:48 GMT -8
Cozwurth makes a good point. You may need several coats of amber shellac to match the old finish.
Post by vikx on Jan 7, 2022 22:54:46 GMT -8
It blends well anyway.
