roadtripper
Post by roadtripper on Dec 11, 2021 17:47:54 GMT -8
Does anyone have a suggestion for putting a refer light inside my 3 way? Maybe battery power? Any way to switch it when the door opens? I also need one in the cabinet under the sink, though wiring this would be much easier. Thanks
Post by vikx on Dec 11, 2021 20:16:50 GMT -8
I would contact your brand (Dometic or Norcold) for advice and information. If it's a 3 way, the 12 volts are at the back of the fridge. I'm not sure you could operate it with a door switch but a simple on/off switch on the light would work.
Post by mobiltec on Dec 21, 2021 10:33:58 GMT -8
Just put a rechargeable LED motion light in there with a piece of double sided sticky tape. They have them as night lights and such on Amazon.
roadtripper
Post by roadtripper on Dec 24, 2021 6:31:57 GMT -8
Thanks much...may get one for the cabinet under the sink too.
Post by bigbill on Dec 24, 2021 17:40:23 GMT -8
Buy LED only they generate less heat and batteries last much longer. You most likely know this but I thought it was worth mentioning.
Post by Teachndad on Dec 24, 2021 21:24:46 GMT -8
All good suggestions, folks.
Would the cold in the fridge effect the batteries?
Cheers,
Post by vikx on Dec 25, 2021 14:20:43 GMT -8
I think the batteries would be OK in an RV fridge. The temperature is usually about 40*. If the refer was on too cold, then it's possible the batteries might be sluggish. Today's lithium batteries are said to work in cooler temps.
