Post by nccamper on Nov 4, 2021 18:03:11 GMT -8
I was going to experiment on a cabinet and piece of the new ash paneling that I bought. But the shellac I have is about three years old. A brand new can. I wonder if it darkens the amber color with time and will it match any new shellac I buy after this point?
Post by vikx on Nov 4, 2021 20:46:28 GMT -8
I've been told that if it is "liquidy" (not thickened), it should be OK. If it has thickened, you can try adding denatured alcohol. You will know if it's gone...
Post by nccamper on Nov 5, 2021 4:26:20 GMT -8
I've also heard that it's best to buy all the shellac use at once hopefully from the same batch. I don't know if it's true.
Post by kirkadie on Nov 5, 2021 4:51:51 GMT -8
Post by vikx on Nov 5, 2021 11:53:45 GMT -8
I've had cans last 3 years+ but it is not overly hot here.
Post by kirkadie on Nov 5, 2021 12:15:51 GMT -8
Hydroscopic nature of shellac causes it go bad after can is opened (talking about Zinsser here), and aged shellac will not dry and harden well. A test is a spoonful in a can top or similar and see how long it takes to dry. Biggest sign of it going bad is when it gums up sandpaper instead of making a fine dust. I believe making your own shellac using wax free flakes is best, but even the flakes have a relatively short lifespan. I make only enough for the project at hand.
