jmcookesq
1966 Frolic, 1965 Aloha
Post by jmcookesq on Nov 3, 2021 3:49:35 GMT -8
I'm trying to put new hubs on a 1966 Frolic single axle and wanted to have the hubs on-hand before pulling the wheels. Does anyone happen to know the spindle size? I can't imagine there was too much variation between models of the same manufacturer (or maybe even other manufacturers?). Thanks in advance for any help.
Post by Teachndad on Nov 22, 2021 6:24:30 GMT -8
Hi.
I know this is an old post from a few weeks ago. You might run into compatibility issues with the new hubs on the old axle. The axles were not made by the trailer manufacturers. I believe the trailer manufactures bought the frames already built by frame manufactures and then built the bodies on top. It might be a Hadco axle.
What did you end up doing?
Post by nccamper on Nov 22, 2021 13:21:27 GMT -8
Thanks in advance for any help. Although I wasn't any help, I wanted to Welcome you...three weeks late.
jmcookesq
Post by jmcookesq on Nov 22, 2021 14:06:22 GMT -8
