halljohns
Post by halljohns on Oct 27, 2021 16:42:56 GMT -8
My 1962 shasta dinette table bench is missing its cushions?
Does anyone know the best place to get replacement cushions or new ones would love to match the old colors?
Does anyone have the original dimensions?
Post by Teachndad on Oct 29, 2021 3:56:58 GMT -8
Hello,
Foam is really really expensive. You can have them made for you, but if you are at all handy, you can go on youtube and scrounge for videos on how to make your own cushions. There are a variety out there.
I wish you could go into a store and just buy them complete. Someone is bound to have the measurements and will post. You will want the total of the cushions to reach the width of your trailer. Most trailers were designed to take the table down and set across between the two dinette benches and then have the cushions placed all the way across forming a second bed.
Cheers,
Post by wisconsinjoe on Oct 29, 2021 7:24:21 GMT -8
Advice about foam: Use high density firm foam for seat cushions. More comfortable for sitting. Plenty of good online places to buy foam custom cut. We used Foam Factory.
oldman
Post by oldman on Oct 29, 2021 9:06:16 GMT -8
I used Foam Factory as well. Not expensive at all.
Post by Hamlet on Oct 30, 2021 0:42:50 GMT -8
High density foam is more comfortable to sit or sleep on. Wrap it with polyester batting, then make a snug plain white cotton coverer it BEFORE you do the outside cover. Make sure the outside cover is super snug as most fabrics will give a little with time and use and will look a little baggy. We made one small mistake when doing ours. We got six inch foam, not thinking how it would impact the height of the assembled cushions. We should have gotten five inch as the assembled cushions cover the bottom half inch of the rear windows in our Compact. you don't really notice it unless you're me or my hubby, but it sure is nice to sleep on!
aslmx
Post by aslmx on Oct 31, 2021 18:10:08 GMT -8
I agree with all above. Use a good high density foam. I tried memory foam in our 65 and it was horrible to sit and sleep on. Our rear Groucho bed I actually used some really good couch cushions that I repurposed. I cut them down to size and glued them together with a good contact cement. Worked great and saved $$$$
gonekayaking
1956 Shasta 1500
Post by gonekayaking on Jul 23, 2022 13:46:27 GMT -8
aslmx
Post by aslmx on Jul 25, 2022 16:04:49 GMT -8
this is awesome.
gonekayaking
1956 Shasta 1500
Post by gonekayaking on Jul 25, 2022 16:42:54 GMT -8
happy to oblige
Post by wisconsinjoe on Jul 30, 2022 18:18:31 GMT -8
You best sitting height is 18" from floor to seat. That will help you decide on foam thickness. Compare to your dining chairs and others you like. Good advice from all above, especially Hamlet
