Post by wisconsinjoe on Sept 14, 2021 17:53:03 GMT -8
I'm getting frustrated with stapling my heavy 40 mil skins. Bending staples at about a 30% failure rate when going through two layers. Have hand hammered nails been used historically and successfully? Any recommendations?
By the way, those skins (inexpensive truck roof metal) were far easier to bend around the radius than I had figured. But, thanks to John Palmer, he suggested just banging it around with hammering a board. A 4 inch wide piece of plywood works fine and leaves a nice hand round. I had to make some some relief V-kerf cuts at the radius, about 5 inches on center, about halfway toward the bend.
But please, someone save me from this stapler hell.
Post by danrhodes on Sept 14, 2021 18:00:44 GMT -8
My camper was half nails. Larry swears by porter cable coated staples for thicker skins.
oldman
Post by oldman on Sept 16, 2021 6:09:04 GMT -8
I have all nails in my camper. It was all nails from the factory as well.
Post by wisconsinjoe on Sept 16, 2021 7:43:56 GMT -8
Yep. Got some 1-1/4" small diameter stainless steel ringshank nails used for cedar shingles. Pre-drill. Go in like a charm. Problem solved. Thanks (again) folks.
