Post by wisconsinjoe on Aug 16, 2021 13:33:04 GMT -8
I want to replace the screws on the Hehr windows that I am rehabbing. These are the tiny ones that attach the glass frames to the crank housing. There are places for four screws, but only two are used. I know I can find these online, but I'd like to know the size and any other specifics that might help. They are under 1/2 inch long. 20210816_161909 by Joe Mirenna, on Flickr 20210816_162042 by Joe Mirenna, on Flickr
aslmx
Post by aslmx on Aug 22, 2021 13:01:34 GMT -8
I’m not sure. I’d be at Home Depot looking at everything close to find them.
Post by vikx on Aug 22, 2021 19:00:07 GMT -8
That looks like the end has been ground flat... Wonder if a sheet metal screw would work?
Post by nccamper on Aug 23, 2021 17:54:30 GMT -8
"Looks like the end has been ground flat... Wonder if a sheet metal screw would work?" Exactly what I did. I couldn't find window screws and had to fabricate them.
Post by wisconsinjoe on Aug 24, 2021 13:01:47 GMT -8
I think I know why those screws had their tips ground off flat. After disassembly and cleaning, and finally reassembly, one of those screws hit the glass from the side and cracked the glass. Fortunately I had an identical replacement pane to clean up and substitute.
Post by vikx on Aug 24, 2021 15:40:19 GMT -8
Lucky to have extra glass. Thicker glass will cause cracks, learned that the hard way. Sometimes it's hard to find the right thickness.
