Post by Teachndad on Jul 21, 2021 4:57:28 GMT -8
Hi Friends, So, what does the title of this thread mean? Well, I was checking up on the lighting on my 1985 pop up for a camping trip. Trailer hadn't been used in a while and I wanted to make sure the lights were working. In the past, a thump was needed to get a few working, but yesterday I wanted to avoid the thump, so I went through checking contacts and bulbs. Just better this way. The tail lights appeared dim, I thought. I have never had a grounding problem with this trailer. I take off the lenses to check for dirty bulbs or dirt inside the lenses. Nope. Not that. I open up both tail lights to check to see if each of the bulbs have the same brightness. I even swapped out with a new bulb. No change. (scratches head) Hmmmmm? It must be that it's in the brightness of the day. So I thought. Get home do the honey this is what I did on my trailer thing and it dawns on me - I had been wearing my glasses which transition automatically to dark in sunlight. (smacks palm to forehead) The tail light bulb brightness was muted due to my tinted glasses. I will go back today and double check sans my glasses. Cheers, Rod
Post by Hamlet on Jul 21, 2021 13:32:31 GMT -8
You know what this means, don’t you?
You’re absolutely normal!
Post by kirkadie on Jul 21, 2021 14:12:13 GMT -8
Wine-out-the-nose kind of guffah here... glad the laptop was far enough away to survive.
Post by nccamper on Jul 22, 2021 5:54:07 GMT -8
That's funny!
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Aug 15, 2021 7:23:06 GMT -8
You’re absolutely normal! Is that abbreviated "ab-normal"?
Post by Hamlet on Aug 15, 2021 20:23:39 GMT -8
You’re absolutely normal! Is that abbreviated "ab-normal"? Young Frankenstein is one of my favorite movies.
