halljohns
Post by halljohns on Jun 29, 2021 11:51:55 GMT -8
Does anyone know the Rim size for a 1964 Shasta trailer and the corresponding wheel specifications?
aslmx
Post by aslmx on Jun 29, 2021 18:29:31 GMT -8
Does anyone know the Rim size for a 1964 Shasta trailer and the corresponding wheel specifications? I put regular trailer tire wheels on our 65. 205/70-15. 5 on 4 1/2 lug pattern.
halljohns
Post by halljohns on Jul 5, 2021 2:55:52 GMT -8
Anyone know where I can find replacement lights (Back & Side) for my 1961 Shasta.
halljohns
Post by halljohns on Jul 5, 2021 2:56:58 GMT -8
Looking to video, direction, or any guidance to replace the front wood panel of my 1961 Shasta?
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Jul 5, 2021 5:46:30 GMT -8
Looking to video, direction, or any guidance to replace the front wood panel of my 1961 Shasta? Give this a whirl, I'll think it will help...
Restoring the 57 Shasta Video Links
Post by vikx on Jul 21, 2021 20:26:46 GMT -8
Looking to video, direction, or any guidance to replace the front wood panel of my 1961 Shasta? You lift the front skin to repair a front wood panel. They overlap the walls and go below floor level. You must get to the wall edges and below the floor to keep the structural integrity of the trailer. Gutting of the inside is never recommended here.
halljohns
Post by halljohns on Jul 27, 2021 6:18:12 GMT -8
I am only looking to replace the front veneer section under the window. This is the only place with water damage.
Post by vikx on Jul 27, 2021 12:30:26 GMT -8
Two very correct answers above.
1. There is no QUICK FIX for a vintage trailer. Sealants will not help you and roof goop will ruin the roof metal, not to mention it won't seal against leaks. All windows, the roof vent and doors should be removed. After cleaning, they can be re-installed with new putty if the framing is in good condition.
2. If you see water stains and damage, there is ROT behind them. You can not repair a stick built trailer from the inside. There is no way to address the skirt and sill boards as they are below floor level. 99.99% of vintage trailers need the skins lifted to inspect and do proper repairs. Most of the rot is below the front and rear windows, lower sill and skirt boards, wood edging and sometimes rafters. (usually due to failed roof metal)
3. A sturdy floor does not mean the rest of the trailer is sound. Good interior panels do not mean the trailer is sound. (especially if there are "minor" water stains at the corners)
4. PLEASE protect yourself and others. Your trailer should be carefully inspected and repairs done before towing. If the body should come loose on the road, whoever following would be in danger. Likewise, a rotten trailer can be out of balance and jerk the tow vehicle off the road. PLEASE protect yourself and others.
Here is an example of an improperly repaired and patched trailer and what happened to it:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/53634851@N03/34821400044/in/album-72157682875554304/" title="Pink Shasta sister 1138"><img src="https://live.staticflickr.com/4285/34821400044_40b260d31b_z.jpg" width="640" height="480" alt="Pink Shasta sister 1138"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/53634851@N03/35275270380/in/album-72157682875554304/" title="Pink Disaster"><img src="https://live.staticflickr.com/4262/35275270380_721b3267b6_z.jpg" width="480" height="640" alt="Pink Disaster"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
All over the Oregon freeway:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/53634851@N03/35493572412/in/album-72157682875554304/" title="Pink Shasta Disaster 3"><img src="https://live.staticflickr.com/4238/35493572412_2b49ddcb83_w.jpg" width="275" height="365" alt="Pink Shasta Disaster 3"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
