emily2662
1964 Shasta 20
Post by emily2662 on Jun 4, 2021 14:28:38 GMT -8
I have a Shasta 20 that I hired someone to fix for me. After they removed the systems and went bankrupt, I got the trailer back in worse shape and lots of questions. I would like to purchase a black tank, the trailer did originally have one (as barely seen in the first photo). I made a mock-up of the desired tank and have a picture of it in place. My question concerns the installation and if this tank is right: There is a space of about 3" between the floor of the trailer and the metal frame. The tank fits tight against the sound board used as a belly pan, and in between the metal frame. Is there a toilet flange that is three inches long to go from the top of the tank to the bottom of the toilet? Should I put a pipe in? Is there something else that I am not aware of? The last photo shows the floor from the inside measuring down to the top of my tank mock-up. IMG_5396 by Emily Andrews, on Flickr IMG_2990 by Emily Andrews, on Flickr IMG_2993 by Emily Andrews, on Flickr IMG_2995 by Emily Andrews, on Flickr
idaho211
Post by idaho211 on Jun 6, 2021 7:44:29 GMT -8
Emily,
Sorry about the outfit going bankrupt and not finishing the job. Was the original tank a different shape than what you are making now? My original blackwater tank on my 19 deluxe was an L shaped tank that fit up underneath the step up bathroom floor. Anyway to get the tank closer to the floor? I know some companies can make a custom black tank to fit your space. In terms of an extension coming from the floor others would have more knowledge if that is possible. Any more pics of the inside floor set up?
Post by vikx on Jun 6, 2021 9:39:54 GMT -8
Be sure the tank is not too low; catching on high ground would not be good. I would go with a shallower tank to keep it safe. Remember, you will be having piping and valves coming from the tank to the outside of the trailer frame. It is too easy to catch that and tear it out, ruining the tank. Is there an experienced RV person you could get to look at your mock up in person?
As far as flange to tank, most flanges are threaded to accept pipe. Measure from the floor to top of tank inlet to get the correct length. ABS pipe is easy to work with and can be adjusted as you go. 3" would be a good size for the trailer.
Also, your trailer floor does not appear to be in good condition. I suggest an added ply layer in the toilet area to be sure the flange will have a secure attachment.
Another option is a porta potti. No expense, no messy hoses to carry and easy dump in a regular toilet.
