idaho211
Post by idaho211 on Jun 3, 2021 6:00:25 GMT -8
Looking for the 15 gauge nails 1 1/2 length that are used to fasten the bottom of the aluminum skin on my Shasta. Anyone have a source? I was looking for galvanized.
Post by vikx on Jun 3, 2021 9:10:17 GMT -8
Most hardware stores carry something similar, tho I use screws on my skins. Makes for much easier repairs when needed. (1/2 x #6 sheet metal-or 3/4 length) They are sharp point, not self tappers. Self tappers tend to enlarge holes and can loosen with time.
Look for #14 x 1-1/2 in. 4-Penny Hot-Galvanized Steel Box Nails at HD. I've found (as many things these days) that the nails arent the greatest and tend to be galvanized roughly, bumpy and course.
idaho211
Post by idaho211 on Jun 3, 2021 10:40:28 GMT -8
V,
I might go with the screws. Like you said would be easier to take out. Do you use more of a pan head screw.?
Post by vikx on Jun 3, 2021 21:38:27 GMT -8
Yes, pan heads. I inherited a coffee can full of 1/2 screws with a house I flipped. They work perfectly for the skin bottom. I only use the 3/4 if necessary.
