glp23
Post by glp23 on May 19, 2021 22:27:58 GMT -8
IMG_0031 by Greg LaPrad, on Flickr IMG_0030 by Greg LaPrad, on Flickr I'm trying to find a freshwater hose for this tank but they seem to be either 1 1/4 inch or 1 3/8 inches. This appears to need a 1 1/2" hose. The tank looked newer but could this be an older tank? Any idea where to buy the right hose for this? Thanks Greg
Post by nccamper on May 20, 2021 4:27:49 GMT -8
I'm sure you tried Home Depot in the PVC section. Maybe a under sink kit would come with something but I would consider a flex pipe that fits over it and clamps in place if you can't find a screw in fitting. Or maybe a sleeve. 1-1/2 in. x 1-1/2 in. DWV Flexible PVC Coupling
Post by vikx on May 21, 2021 11:04:21 GMT -8
Or look at "Fernco" fittings. They make straight fittings and reducers.
Post by vikx on May 23, 2021 9:46:04 GMT -8
Beware the RV smooth bore hoses!! They are not the same size as normal USA plumbing fittings!
