PT
Post by PT on May 16, 2021 15:20:28 GMT -8
I found a Dexter 3500LB 4" drop axle (Dexter part number 4766665) that is 78 inches wide hub face to hub face (one inch wider than the one I will have to replace). I have about 2.5 inches between the outer tire edge and the inside of the wheel well currently so I believe the tires will still fit in the wheel well...
Question - The specs for the Dexter axle call out spring centers from 60-64 inches. The springs on the Holiday House are 56.5 inches center to center. Is this 60-64 inch range an absolute requirement or can I cheat by 3.5 inches?
I'll be asking the shop when I call tomorrow but curious if anyone else has dealt with this?
Thanks
Post by nccamper on May 17, 2021 3:46:53 GMT -8
Where will you order your axle from and how much was the whole assembly? I may be coming to the same point soon.
sawset
1958 Mobile Scout
Post by sawset on May 17, 2021 6:09:09 GMT -8
I recently custom ordered an axle for a trailer that I was building. It was the same as those listed as so called part number axles available (Dexter part number xxxxxx), except that I was able to spec the drop, hub face width, and spring center width, and the hub bolt pattern to match the existing wheels. Mine was a torsion type, about 56" mounting centers, $280. I believe the straight and straight/drop axles have a welded bracket to except the spring mounting. Not sure if a ubolt and bolted bracket would suffice, but the location should be able to be variable if it is. I ordered mine through a distributor 20mi away, so no shipping. I just filled out their form, spec't everything required, 3 weeks to pick it up. That way I didn't need to try to fit and axle that was available but not quite right. Pioneerwheel has locations in Fargo, Minneapolis, and Madison WI, and has order forms on their website.
PT
Post by PT on May 17, 2021 11:19:54 GMT -8
Thanks - This place has been recommended to me by a few knowledgeable people. sixrobblees.comThey did not carry the 3500LB 78 inch Dexter axle I found online and the guy I talked to did not think moving the spring seat outside its recommended range was a good idea. BUT - they do have a spot on 77" (hubface to hubface) highway rated 4 inch drop axle in their Seattle warehouse They can have it shipped here by next Tuesday. It works with 6 on 5.5 hubs so I can keep my existing rims with hubcaps and tires. Axle, bearings, hubs, brake assemblies appear to be in the mid $700 (could have been less if I went with Chinese options) range which is in the ballpark of my earlier plan to have a custom axle built and outfitted with brakes. I'm learning more about trailer axles and brakes than I ever wanted to know...
