laurajean
58 Shasta Airflyte
Post by laurajean on Apr 28, 2021 13:06:35 GMT -8
I am progressing nicly with my 58 restoration got my new roof all set to be installed. I realized that my camper is just set up for 30amp to supply 110 v system including small retro fridge, 19" tv and then everything else electric which is not much. I wanted to replace the old vent which caused 99% of the damage to the roof, which is GONE now. Then realized that the fan's are all 12v. Or at least I am thinking so. What do you think are my best options. Is there a 110V motorized fan. Or can I convert the 12v with a 110?
aslmx
Post by aslmx on Apr 28, 2021 17:50:11 GMT -8
Post by vikx on Apr 28, 2021 21:17:49 GMT -8
Your best bet is to disconnect the vent wiring from the 110 system and use a 6 amp 12 volt converter to operate a Fantastic Fan. Connect ONLY the Fan wiring to the converter and you'll have it done.
