pdalber
Post by pdalber on Mar 15, 2021 5:03:38 GMT -8
I'm trying to decide between the checkerboard pattern or a solid color. Thoughts?
idaho211
Post by idaho211 on Mar 15, 2021 6:12:26 GMT -8
For counters?
pdalber
Post by pdalber on Mar 15, 2021 6:37:08 GMT -8
Flooring - in the images, VCT tiles are on the left and countertop laminate is on the right
Post by vikx on Mar 15, 2021 21:07:48 GMT -8
Checkers.
Andy Smith
1955 Aljoa Model 16 Sportsman
Post by Andy Smith on Mar 16, 2021 6:44:53 GMT -8
Checkers! You’ll find the floor looks cleaner than having a solid color, where anything not that color will stand out like a sore thumb.
Post by Hamlet on Mar 16, 2021 8:59:11 GMT -8
I like the checked floor tiles, especially for the clean thing. You obviously have some concern about too many patterns, not an invalid concern when there is still upholstery and curtains to think about. You might want to consider putting texture, rather than pattern, into the curtains, and something subtle in upholstery to avoid making a small space look busy. You’ll figure it out and it will be fabulous!'
pdalber
Post by pdalber on Mar 16, 2021 9:24:30 GMT -8
I'm thinking of these patterns as well. They would not be as "busy" and the grays in the laminate look really nice with aluminum trim. My only concern would be if the browns would look good with the amber birch interior.
Post by Hamlet on Mar 16, 2021 11:09:55 GMT -8
Love the laminate. And you could do the amber birch if you chose fabrics that pulled in both colors. Tnings don’t have to match, just blend. Hamlet is blue and off white outside. The floor is darkish red and off white Marmoleum with kind of a golden yellow basket weave laminate, we went with red and white mattress ticking for curtains and stuff bags for our bed pillows. The fabric for he cushions is a Route 66 retro heavy cotton tapestry that pulls in all the colors. It’s not overwhelming at all, just kind of classic. We bought our fabric online. You can get samples sent so you can have a good idea of what the end product will be.
After all the work getting all the invisible structural things taken care of, it’s so much fun to do the aesthetics. Good luck!
Post by nccamper on Mar 16, 2021 13:04:10 GMT -8
pdalber
Post by pdalber on Mar 17, 2021 5:07:31 GMT -8
Post by Hamlet on Mar 17, 2021 10:09:59 GMT -8
Ooh, that's gorgeous. Marmoleum is a bit different to work with than VCT, it's lighter weight and more flexible, which made it easier for my hubby to do an inlay as a little decoration. There are a couple other true linoleum products out there. Marmoleum is still made by a European company, I think, and the tiles were metric and just a little larger than 12 inches. It has held up beautifully over the past decade of pretty heavy use. This pattern (it looks like sheet rather than tile, although most patterns come in both) would hide dirt beautifully and look gorgeous with the tone of the birch paneling.
Post by vikx on Mar 17, 2021 12:40:11 GMT -8
Love the stripedy tile!
Post by Hamlet on Mar 17, 2021 15:29:53 GMT -8
I’m pretty sure it comes both in sheet and tiles,
pdalber
Post by pdalber on Mar 18, 2021 9:36:15 GMT -8
That one is a sheet - I really like it and I'm looking at purchase options. Also, on another note, I finally found a source for 1/8" bending birch plywood in S Florida (and it's "only" an hour away). I'm actually pretty excited about that because I made A LOT of calls, and was beginning to think I wasn't going to find any.
Post by Hamlet on Mar 18, 2021 12:25:47 GMT -8
That one is a sheet - I really like it and I'm looking at purchase options. Also, on another note, I finally found a source for 1/8" bending birch plywood in S Florida (and it's "only" an hour away). I'm actually pretty excited about that because I made A LOT of calls, and was beginning to think I wasn't going to find any. Try to find a local mom and pop business. The Marmoleum won’t cost any more, you’ll be supporting a local business, but the best thing is something that big box stores just can’t offer: service. They can give you tips on installing, even if you have to do it outside in the cold. If you decide to get a small piece (remnant or single contrasting tile) and do an inlay, they can guide you through that as well. HD and Lowe’s can’t do that.
