idaho211
Post by idaho211 on Feb 2, 2021 14:21:45 GMT -8
I have a 1958 Shasta Deluxe with the bathroom /shower up near the front by the dinette. The previous owner took out the toilet waste tank and the plumbing. Does anyone have an original set up of the toilet with the waste tank , plumbing and drain system? Pics would be great underneath the trailer to see how it is run. In the bathroom the place where the toilet is has the corner of the floor cut off into a diagonal to accommodate the outside wall. Is the waste tank corner notched to fit that as well? I appreciate the help.
Post by vikx on Feb 2, 2021 17:22:28 GMT -8
Email me for pix of the fiberglass tank on a Deluxe/SS.
idaho211
Post by idaho211 on Feb 4, 2021 16:50:40 GMT -8
Thanks V.
Does anyone have an intact original system? Trying to figure out the sewer lines as well as where the fresh water coursed. Did the freshwater outlet pipe come down thru the floor and then traveled by the frame underneath the floor then branched off and came up thru the floor to supply water to the toilet? Did it then continue to course under the floor along the frame and come up under the sink? I see an original hole in the floor under the sink.
Appreciate any pictures
Thanks
