PT
Post by PT on Jan 16, 2021 16:28:30 GMT -8
Hoping someone has a trick to help make this go faster...
I have a 5' x 2' solid window and most of the glazing tape is still firmly affixed to the window. The window is on the floor - glass well supported, etc. Beyond using a flexible slim razor knife blade and picking, poking, slicing away between the glass and window aluminum are there any trade secrets out there? I start in the areas where the tape has lost its grip to the glass but once I get to the areas where its still sticky progress drops to near zero.
Maybe a few drops of mineral spirits on the razor or into the channel... or just endless elbow grease?
Thanks!
aries
Post by aries on Jan 16, 2021 19:01:50 GMT -8
I used a heat gun on front Aloha plexi window,the stuff looked like hardened cement tape but eventually worked free.The rear paper glass widow wasn’t so lucky on🙄But still used heat gun for easy frame clean up.This method may not work for all situations in density of hardened crud but maybe worth a try?As always,,,very nice job Allan!
Post by John Palmer on Jan 16, 2021 21:22:30 GMT -8
Agree, use a heat gun.
Drip a little Goo Gone on both sides of the sticky goo, let it soak, and get after it with the heat gun.
John
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Jan 17, 2021 6:20:17 GMT -8
I find that when trying to remove sealants, heat is my preferred choice. I usually heat the metal from the back side to get the sealant (putty, butyl, silicone, whatever) to release rather than heating the sealant which can just make a gooey mess and still leave residue on the metal.
...and here's an added tidbit: For old home glazed windows, we have a tool that lays flat on the glass with a heating element along two edges. The heat produced will even aid in removing the old, dry glazing putty around the wood frame hardened from years gone by. (my family did window glass repair for close to a hundred years)
That's why heat is my "go to" method.
Just my opinion, didn't say it was a good one... Whitney
PT
Post by PT on Jan 17, 2021 8:03:27 GMT -8
Thanks all.
I'll track down my heat gun and get after it :-)
Post by mobiltec on Jan 26, 2021 8:21:16 GMT -8
Thanks all. I'll track down my heat gun and get after it :-) No heat gun needed. Use the Multi-Tool with the putty knife style toothless blade on it. That will make quick work of that black glazing tape.
PT
Post by PT on Jan 27, 2021 10:33:45 GMT -8
I'd thought about trying exactly what you mention and in retrospect wish I had.
Even after heating the frame and glass to a point where it was way too hot to touch I had to exert a great deal of pressure on the razor blade to make any progress. Took hours to get the glass out and the edge was heavily chipped in the process so am getting new glass anyhow. Between risking cutting off fingers and aching wrists and elbows this was about the least fun I've had on HH rebuild. New 1/8" glass cut to size was only $37...
