theresa
Post by theresa on Dec 29, 2020 15:45:37 GMT -8
Hey folks, sorry for the barrage of questions lately... getting finished up and the LAST piece I have to put on is the strikeplate. The original seems to be pot metal which appears to have once had a little flange on the back that is broken off. Is this an issue? Has anyone replaced their strike plate with a random one from a big box store? I have all new metal on the door frame and jamb so I won't be re-using any existing holes, etc. Here are two photos of my strike plate to try to show the detail of it. Thanks in advance! 2020-12-29_06-40-54 by t_in_maine, on Flickr 2020-12-29_06-40-41 by t_in_maine, on Flickr
Post by nccamper on Dec 29, 2020 16:00:34 GMT -8
I don’t think the missing tab will make a huge difference. I have replaced the strike plate with one from Lowe’s in the past. Although I think you’ll be fine. The hardest part is lining it up so that the door isn’t too loose or too tight. A lot depends on your weatherstripping/gasket around the door.
The nice thing about the tab is you can bend it slightly to tighten up the door if needed. Does that make sense?
theresa
Post by theresa on Dec 30, 2020 6:01:00 GMT -8
I don’t think the missing tab will make a huge difference. I have replaced the strike plate with one from Lowe’s in the past. Although I think you’ll be fine. The hardest part is lining it up so that the door isn’t too loose or too tight. A lot depends on your weatherstripping/gasket around the door. The nice thing about the tab is you can bend it slightly to tighten up the door if needed. Does that make sense? oh wow, there was NO weatherstripping/gasket around the door at all when I got it. Do you have any photos of this or a link to what might have been there on any of your Shastas?
Post by nccamper on Dec 30, 2020 17:49:30 GMT -8
This is what I've used.
Will this work for a strike plate?
