Post by MapleRiverShasta on Dec 15, 2020 1:51:03 GMT -8
Hi all, was wondering if anyone knows what brand of window this is? As you can see it is missing a glass louver and louver aluminum frame. Any suggestions on what I can do? I have been looking online for a replacement but no luck yet. Rough opening is 30 1/4" wide x 15 1/2" tall, TIA IMG_1295 by Carol Donley, on Flickr
Post by John Palmer on Dec 15, 2020 9:02:52 GMT -8
Have you considered actually making a new replacement frame?
Find a old donor window of the same model, and cut it down to your required size.
VTS (Vintage Trailer Supply), and VTG (Vintage Trailer Gaskets) sell the gaskets and parts for these windows.
VTS even sells some of the extrusions.
I would guess it's a Hehr Clear View model, have you looked for the model numbers stamped into the back frame?
The corners are mitered, and screwed together on most windows. Some windows have a welded corner, which can be done "at home" with the low temperature Alumi weld from VTS.
The glass comes from your local hardware store.
It's very "doable"
John
Post by vikx on Dec 15, 2020 21:45:01 GMT -8
Check with trailertrasher1@gmail.com. He sells used parts.
Post by MapleRiverShasta on Dec 16, 2020 3:01:43 GMT -8
Check with trailertrasher1@gmail.com. He sells used parts. I sent him an email, just waiting on response. Thanks Chris has a window that's my exact size and type, he's shipping soon. Thanks again Vikx
Post by MapleRiverShasta on Dec 16, 2020 3:03:12 GMT -8
Have you considered actually making a new replacement frame? Find a old donor window of the same model, and cut it down to your required size. VTS (Vintage Trailer Supply), and VTG (Vintage Trailer Gaskets) sell the gaskets and parts for these windows. VTS even sells some of the extrusions. I would guess it's a Hehr Clear View model, have you looked for the model numbers stamped into the back frame? The corners are mitered, and screwed together on most windows. Some windows have a welded corner, which can be done "at home" with the low temperature Alumi weld from VTS. The glass comes from your local hardware store. It's very "doable" John Yes I am trying to find a donor model to cut down to size. Thank you for your great advice!
klynfry
Post by klynfry on Jul 7, 2021 16:40:20 GMT -8
I have a 1964 Ionia-a-Home trailer. The windows look just like the one in the picture. I have tsken some apart as there's glass missing. Cleaned the aluminium and purchased new gaskets from Vintage gaskets. There is a tiny "bent just so" piece of metal that holds the bottom of the glass into the aluminum frame. Some of mine are either lost or broken. Any clues as to what can be done about it. I would send photos, but after reading how to send pictures to this forum it I figured I would be too old to care.
