cu879
Post by cu879 on Oct 12, 2020 9:04:08 GMT -8
I am working on a pop up camp trailer that has 2 12” x 25” windows. I have the frames, but do not have the hinged outer glass frame or the lever parts. I am looking for someone that has these parts for sale? If not, I am considering trying to build my own. Does anyone have decent photos of the glass frame and the rolled hinge edge? flic.kr/p/2jTaV1tflic.kr/p/2jNB2Pdflic.kr/p/2jNxoDj
Post by John Palmer on Oct 12, 2020 9:28:38 GMT -8
You need some more information before you start your search.
Hehr is just a company that makes RV windows. THey have been around for a very long time, and they have made many different models of windows. The Hehr window model you have is called a Hehr Standard, it was one of the windows the built during the 1950's, fortunately you can buy replacement seals from VTS. You will require their glass seal, and also their back frame gasket.
You have only the back frame (the stationary part), your missing the moveable window. You should be looking for a entire window assembly IMO. Nobody is going to break up a complete window to sell you only the front part. You buy windows by the rough opening size.
Chris, aka Trailertrasher on this site is a good source for windows, He has hundreds of different windows for sale. Someone will have his address.
John
Post by nccamper on Oct 12, 2020 9:56:11 GMT -8
trailertrasher1@gmail.com
I agree with the post above, you will probably need a replacement window. You're missing too many pieces to make repairing it practical and cost effective.
cu879
Post by cu879 on Oct 12, 2020 11:20:47 GMT -8
Is there a good source for used windows?
Post by John Palmer on Oct 12, 2020 15:54:49 GMT -8
Is there a good source for used windows? LOL, It's like a crossword puzzle. Clue, check posts #1 and #2, John
cu879
Post by cu879 on Oct 12, 2020 17:29:47 GMT -8
I assumed that Trailertrasher would have said in his post he had a couple in his inventory for sale? Perhaps I shouldn’t have assumed. I will reach out and see what he has.
Thanks for the info.
ekimnamniets
Post by ekimnamniets on Oct 13, 2020 6:02:33 GMT -8
I have an extra Hehr window I don't need. What are the dimensions of your window?
cu879
Post by cu879 on Oct 13, 2020 19:58:14 GMT -8
I’m not sure where the size is measured from. The opening size on the trailer Is 24” x 10 1/2”. The overall size is 25”x 12”.
Post by John Palmer on Oct 13, 2020 20:21:28 GMT -8
I’m not sure where the size is measured from. The opening size on the trailer Is 24” x 10 1/2”. The overall size is 25”x 12”. You buy windows by the rough opening size. It's the hole in the wall framing. Length and height. In your case, it sounds like you need a 24" wide, by a 10 1/2" tall "Standard model" Hehr. John
mnglamper
Post by mnglamper on Oct 18, 2020 13:56:24 GMT -8
I have the same problem with a 1960 airstream that I just purchased. The inner window was missing. I found that the front window was the same as the back. I took the front window out and brought it to a metal fabrication shop. they said that there is no way to form the rolled edge. they will weld an aluminum piano hinge to preform the same function and build me the frame. not sure of cost but will not be cheap.
Post by John Palmer on Oct 18, 2020 18:30:20 GMT -8
I have the same problem with a 1960 airstream that I just purchased. The inner window was missing. I found that the front window was the same as the back. I took the front window out and brought it to a metal fabrication shop. they said that there is no way to form the rolled edge. they will weld an aluminum piano hinge to preform the same function and build me the frame. not sure of cost but will not be cheap. No point in making these challenges more difficult than they already are. All you need to do is find a replacement window of the same make and model. Many times, you don't even need the correct size, and only need parts of the window assembly. The "rolled metal" Hehr hinge on their Standard model window is just riveted to the frame. You drill out the rivets, take the hinge from your donor window and re-install it. Many times you need to take a window apart (by drilling out rivets) anyway just to clean, sand, and polish the seventy years of corrosion. Working on windows is not difficult, it usually requires only plenty of time, and hard cleaning. I don't see how you could have any "professional shop" do this kind of work without spend tons of money. IMO, anyone can do windows and expect to get a professional result. Why would your metal fabrication shop need to weld on a new piano hinge on, when the original hinge was simply riveted? Chris, aka the TRAILERTRASHER has hundreds of different vintage windows "in stock". He's reasonably priced, will work with you on the best way to ship. Considering the nature of this product, he's truly a great resource. John
