kanolan
Post by kanolan on Sept 18, 2020 9:29:25 GMT -8
We need to replace some of the paneling behind the kitchen area due to rot. The original panels were four pieces that came together around the window (the seams were hidden behind the cabinets and formica walls). I'm wondering if we should put it back as four separate pieces, of if we should cut one large piece with a window opening? I'm guessing there's more stability in a single piece, but that there could be more flex in multiple pieces if that flex is important for carrying down the road. What have others done? Thanks!
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Sept 22, 2020 8:42:46 GMT -8
We need to replace some of the paneling behind the kitchen area due to rot. The original panels were four pieces that came together around the window (the seams were hidden behind the cabinets and formica walls). I'm wondering if we should put it back as four separate pieces, of if we should cut one large piece with a window opening? I'm guessing there's more stability in a single piece, but that there could be more flex in multiple pieces if that flex is important for carrying down the road. What have others done? Thanks! Well, yes, yes, and uh, yes. In my opinion, whatever is easiest for you and your skill level, can the seams be hidden, and will you be satisfied with your results. Yes a single panel is more structurally sound than small panels that are stapled / nailed along the edges. Yes, if the engineers said it was ok at the factory it's probably ok now, then again, they usually tried to use up all the pieces to reduce waste. Yes there is flex with the smaller panels, but, is it needed. Just my $.02 worth.
