Post by Teachndad on Aug 9, 2020 6:46:32 GMT -8
Hello Friends,
Just a thought while reading a recent thread on window seals. It reminded me of the difficulty I had installing my D-Seal on my Hehr jalousie window. I just found a tip on the Vintagetrailersupply website. Dip the D seal in soapy water first before installing or coating it with powder which I assume is talcum powder and then insert.
I had a question, though. What happens if you put it in warm soapy water and then stretched it like a rubber band and then had a second person push the inserted part of the D- seal into the track as it was stretched? I just wondered if stretching it would narrow the part that goes into the groove and as it recoiled after inserting, it would fill up the gap.
I would try it, but I don't have another jalousie window to try this with. BTW, my experience was with a model 4 J 30 which is very similar in size and construction to the model 1626 that Larry restores in his Repairing a Jalousie Window video. The key difference is how the screen is mounted.
Post by nccamper on Aug 9, 2020 9:39:28 GMT -8
I wonder if the rubber band system will leave the seal stretched?
I spray WD40 on the channel to help slide in the seals in place.
Post by vikx on Aug 9, 2020 11:58:24 GMT -8
I use spray silicone. It slicks the channel really well.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Aug 9, 2020 17:54:29 GMT -8
Be careful with the WD40 nccamper, it tends to deteriorate the rubber over time. Have changed things made of rubber that WD40 was used to assemble, (mount tires) makes a black, nasty mess. JMHO...
Post by Teachndad on Aug 10, 2020 6:13:37 GMT -8
Be careful with the WD40 nccamper, it tends to deteriorate the rubber over time. Have changed things made of rubber that WD40 was used to assemble, (mount tires) makes a black, nasty mess. JMHO... Hi Friends, Whitney beat me too it. I was going to mention this same thing. When I installed the D- Seal on my jalousie, I tried a water based lubricant because I didn't want to use a petroleum based product. According to Wikipedia, it's WD 40 is 35% petroleum. I was worried it would contribute to the decay of the D- Seal material. The water based lubricant I used didn't work, though. After about two inches, I could only move about an 1/8" at a time. It was a very tedious, arduous, and time consuming process to "inch" the D- seal forward. It almost reactivated some carpel tunnel issues. I did clean out the groove rather well before attempting. I wonder if the external temperature plays a role. Rod
