idaho211
Post by idaho211 on Jun 18, 2020 17:11:35 GMT -8
So background info. Rebuilding pull out goucho on my 57 deluxe. It looks like the ash faceboard sits on top of the pullout plywood. The problem I had was the attaching hardware. Glued clamped pre drilled and tried to screw in a wood screw. Half way in and it broke off. Abandoned that and nailed with 3D finish nails. I bent a few nails. Not pretty but done. Any future advice about attaching hardware to hardwood in the future. I like the ash but don’t want to go thru that again!
Post by vikx on Jun 18, 2020 21:27:50 GMT -8
Pre-drill every time. Sometimes wax on the screw helps. I use screws designed to be driven by a drill/driver. The don't break as easily.
idaho211
Post by idaho211 on Jun 19, 2020 17:35:00 GMT -8
I will look into those screws. Ash is hard wood but pretty. Thanks for the advice.
idaho211
Post by idaho211 on Jun 19, 2020 18:42:41 GMT -8
Getnold
1957 Westerner Pony Express
Post by Getnold on Jun 20, 2020 10:05:18 GMT -8
I used all solid ash, ash plywood and panels. Cheep screws just tore right up. Square heads worked best but we used a lot of phillips as well. We used Lath Sharp Point Screws, predrilled or we used predrilled Finish Self Drilling Screws with Finish washers. Predrilling the correct size hole is key with the hard ash. Love the look though! Good luck!
idaho211
Post by idaho211 on Jun 20, 2020 14:19:44 GMT -8
Getnold,
Thanks for the specifics. I will look for some.
timanddana
1960 Shasta Deluxe 19'
Post by timanddana on Jul 8, 2020 9:26:51 GMT -8
beautiful!
