gcanyon17
Post by gcanyon17 on May 17, 2020 11:35:19 GMT -8
I have a 1965 aristocrate dual axel. I would like to take it on forest road occasionally. Has anyone flipped the axels and if so any big issues I should worry about?
Post by nccamper on May 17, 2020 17:43:26 GMT -8
Welcome!
I've heard it messes with the center of gravity and puts added stress on parts of the axle that were designed for it.
gcanyon17
Post by gcanyon17 on May 17, 2020 20:07:54 GMT -8
ok thanks for heads up. Ill check into other options to give my trailer a few more inches.
Post by vikx on May 17, 2020 21:35:04 GMT -8
I agree; flipping the axle can cause the tires to wear funny as well. There are lots of ways to lift your trailer safely. Let us know what you find.
swpatriot
1969 Aristocrat Lo Liner
Post by swpatriot on May 29, 2020 12:05:11 GMT -8
I agree; flipping the axle can cause the tires to wear funny as well. There are lots of ways to lift your trailer safely. Let us know what you find. What are some of the Other ways to lift your trailer safely?
aries
Post by aries on May 29, 2020 14:52:28 GMT -8
My axle was underslung when I bought it,purchased new axle with elec brks and left it the same,gives a few inches for trlr clearance and tire change,yet axle will remain same height. Good luck with your judgement on them back roads👍 Mark
Post by vikx on May 31, 2020 20:13:36 GMT -8
Spacers and axle placement help lift the trailer body. Do research before any changes are made. Also, tandem axles are different than our single axles, so more parts and effort may be necessary.
oakback
Post by oakback on Jun 2, 2020 6:48:16 GMT -8
Personally, I'd find a local shop that does lifts on trucks, and ask them about it. There are right and wrong ways to lift a leaf spring suspension, and these shops have lots of experience in what works. If you need new hangers welded to your frame, or custom shackles made, they can do that too (probably for cheaper than you'd expect).
