Post by Teachndad on May 2, 2020 5:28:04 GMT -8
Hi, There is a hole in the bearing cap. Why? Has it been enlarged?
Thanks,
Post by nccamper on May 2, 2020 6:58:10 GMT -8
My guess is that someone had trouble getting it off and used a sledgehammer to drive a screwdriver in and twist it.
Post by bigbill on May 2, 2020 17:57:33 GMT -8
I agree the hole was probably caused by some not knowing how to remove the cap. It should be replaced or brazed shut.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on May 3, 2020 6:00:16 GMT -8
...OR the last person to pack the bearing left the cotter pin a little long and it rubbed and eventually wore through.
Post by Teachndad on May 4, 2020 3:46:34 GMT -8
Thank you, everyone.
