BruceO
Post by BruceO on Apr 4, 2020 15:30:13 GMT -8
I'm looking for a 2"-3" wide aluminum trim piece to cover where 2 skins overlap. Any ideas where I can buy a 8' piece?
ekimnamniets
Post by ekimnamniets on Apr 4, 2020 15:58:36 GMT -8
Guttering & roof flashing should work. Comes in 10' or 20' roll if I'm remembering correctly.
Post by ladywendolyn on Apr 4, 2020 18:38:43 GMT -8
bruceo do you mean along the edge of the roof? Photos will help as there are specific types of trim for different parts of the trailer.
aries
Post by aries on Apr 4, 2020 21:28:38 GMT -8
Nice if you find it,I've been looking a long time for the same dimensions,some type of malleable alum for edgeing on rock guard🤔
BruceO
Post by BruceO on Apr 5, 2020 1:16:01 GMT -8
I'm looking for the piece that runs on top from side to side (about 7') and covers where 2 pieces of roof skins overlap.
Post by nccamper on Apr 5, 2020 4:01:03 GMT -8
Welcome!
Is it leaking there? Damaged? Was there a trim piece there before? Photos may help us understand what you're trying to accomplish and offer suggestions.
Post by ramblingamblinman on Apr 5, 2020 7:56:53 GMT -8
Here is what I used:
Rub railOur Holiday Rambler had a narrow aluminum strip across the roof seam originally but it wasn't salvageable. Looked everywhere before settling on this. Not the cheapest fix, but worked. I filled the void with several layers of putty tape and put the screws in the channel. vintagetrailersupply.com/airstream-rub-rail-1956-65-vts-211/
