doublet54
1960 Kenskill
Post by doublet54 on Aug 15, 2019 11:35:01 GMT -8
Has anyone seen or learned an effective way to join together 2 pieces of drip/J rail so to avoid leaking? Mine are 8 feet long sections and there are a few seams.....
Thanks,
John
Alaska Shasta
1964 Shasta
Post by Alaska Shasta on Aug 15, 2019 15:56:32 GMT -8
Perhaps gutter sealer if the joints are not too far apart? Clear and slightly pliable when dry.
Post by vikx on Aug 15, 2019 19:33:50 GMT -8
The putty will ooze out between the two or at least it should. Gutter seal will help but putty is your first defense against leaking...
doublet54
1960 Kenskill
Post by doublet54 on Aug 16, 2019 6:50:48 GMT -8
The putty will ooze out between the two or at least it should. Gutter seal will help but putty is your first defense against leaking... Was referring to butting J Rail up to J rail, emailed Mobiletec and he said the same thing, gutter seal, to prevent water from dripping down the side of the trailer and discoloring the side.... Thanks for the feedback!! John
