kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jul 4, 2019 9:41:30 GMT -8
So I got a circuit breaker for the charge line on my 7 pin tow wires. It won't fit in my J box with all the tow wires (bought one on Amazon). Do I need to add another j box to put this in? For the 2 posts on circuit breaker- do I have this right: -one post is for hot battery line coming off the fuse block in the trailer -other post is for (1) black wire from 7 pin tow line and (2) positive line to battery. Do I have that right? So confusing Thanks Kathy
Post by bigbill on Jul 4, 2019 16:11:47 GMT -8
I'm a little confused about what you are asking but if you are talking about the wire that charges your trailer battery as you drive down the road, it should have a fuse or breaker on the car end where it connects to the car wiring. I think you are describing the proper hook up for the breaker. But I would install a fuse or breaker at each end of the wire since it has the potential to be hot from either end. I hope I understood what you were asking.
Post by vikx on Jul 4, 2019 20:19:05 GMT -8
The circuit breaker can go in a small box under/near the tongue. Many new RV's leave them exposed. I put mine in the 2 gang box containing the tow wiring and hot into the trailer. Your box is very different, I don't use that kind.
The circuit breaker itself is labeled Batt on one post and Aux on the other. The battery hot goes to the Batt as does the 7 way charge line. Aux is for the hot into the trailer to the fuse box.
WhitneyK
'67 Shasta Compact
Post by WhitneyK on Jul 5, 2019 7:02:10 GMT -8
I just put my in-line breaker near the battery in the battery box to protect it from the weather. Right or wrong, not sure, but it's been working for 7 years and almost 35k miles with no issues.
Again, jmho
Post by bigbill on Jul 5, 2019 11:19:20 GMT -8
I just put my in-line breaker near the battery in the battery box to protect it from the weather. Right or wrong, not sure, but it's been working for 7 years and almost 35k miles with no issues. Again, jmho That is the best place to have it. In a newer vehicle they have the charging wire fused on the vehicle end so a braker at the trailer battery is all you need. On an older vehicle that you have to run a wire to the trailer plug from your power source then use a breaker at both ends.
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Jul 5, 2019 12:10:17 GMT -8
Thanks all- we got it done today. Tested all the trailer wiring- and EVERYTHING is working!!! Yahoooo!!! Been a long time coming- but she's done. Metal starting to go on tomorrow-so happy
