kristi
Post by kristi on Dec 11, 2013 14:34:48 GMT -8
Recently we had difficulty sliding our own awning along the rail, when it usually glides easily. We struggled to get the awning to the end of the channel, when out tumbled a pile of nut fragments! Apparently the squirrels must have been having a nut cracking party on our trailer, even though it is stored under an aluminum shed. Live and learn! So be sure to clean out the rail with a test tube brush and some soapy water. It is an easy job that will prevent a frustrating experience. If you have a vinyl welt on your awning, sometimes in cold weather Blaster Dry Lubricant can make it slide easier. The cold seems to make the welt stiffer and the aluminum channel contract, while during warm weather it glides easily. Recently at a Rally I helped another Rally participant set up her awning, which was very difficult to pull along the rail. Blaster came to the rescue!
Post by vikx on Dec 11, 2013 22:56:26 GMT -8
Good info and thanks. I've had a few problems myself.
lovnvintage
Post by lovnvintage on Dec 12, 2013 4:40:08 GMT -8
Thanks for the tips and on cleaning too!
Nomad95336
1961 Nomad 16'
Post by Nomad95336 on Dec 18, 2013 2:31:06 GMT -8
On the old board, didn't someone show a pic of a doo-hickie made from an Eye Bolt and a small pully to easily assist awning install?
Shemp & Bunny 62 Nomad Manteca, CA
kristi
Post by kristi on Dec 18, 2013 13:31:52 GMT -8
Post by SusieQ on Dec 18, 2013 14:51:13 GMT -8
Has anyone ever tried rubbing paraffin on the awning rail or nylon rail insert? I've got a few months to go, but I'll try it and let you know how it works.
Post by John Palmer on Dec 18, 2013 15:45:54 GMT -8
Paraffin, or Bees wax will work, but they get soft and sticky in warm weather, which will attract "more dirt" in the track.
Just clean the track with some denatured alcohol, and rub a bar of soap on the canopy welt strip every few times when you use it.
Post by bigbill on Dec 18, 2013 17:44:05 GMT -8
We used to rub the welt with wax paper and it worked like charm, not enough build up to attract dirt but enough wax to let it slide easy. Also if you have kids or grand kids camping with you and the play area has a slide that isn't slippery take a piece of wax paper and let them sit on it and slide down a few times to wax the slide. May take a few sheets.
