Post by michaelaj99 on Jan 29, 2019 7:41:27 GMT -8
1954 Shasta frame off restor My trailer has no toilet just a sink so aren’t I looking at a hole in the tank for the P -trap, a hole for the guillotine valve and some vent system? Do I really need to put a 1 1/2 vent pipe from my gray tank through the trailer and out the roof? Isn’t there a much less obtrusive, equally productive approach? Any videos out there that don’t include directions on plumbing showers and toilets too? I Just need simple.
PT
Post by PT on Jan 29, 2019 8:23:40 GMT -8
n2hcky
1967 Serro Scotty Hilander
Post by n2hcky on Jan 29, 2019 9:09:20 GMT -8
That is exactly what I am suing and doing in our Scotty. Gonna get the roll around tank since most places won't allow grey water on the ground.
windborn
1957 Sportcraft 15
Post by windborn on Jan 30, 2019 6:16:08 GMT -8
Could someone explain to me how that drain works? I currently just have a plastic tube clamped directly to my sink and running outside. Does this have any benefit compared to that?
(Asking as someone whose plastic tube is currently clogged, which happens every few months when food sneaks under the mesh drain cover.)
oakback
Post by oakback on Jan 30, 2019 6:22:00 GMT -8
They screw onto a standard sink drain, and the other end is a 3/4" fitting (standard garden hose fitting). The tube in between is easy enough to remove and cut, or you can replace it with a longer tube. I don't think it would necessarily be better than a clamped hose, but it is "plug and play", it screws right on. No trial-and-error finding out how to get a sink drain to a smaller hose.
windborn
1957 Sportcraft 15
Post by windborn on Jan 30, 2019 7:38:50 GMT -8
They screw onto a standard sink drain, and the other end is a 3/4" fitting (standard garden hose fitting). The tube in between is easy enough to remove and cut, or you can replace it with a longer tube. I don't think it would necessarily be better than a clamped hose, but it is "plug and play", it screws right on. No trial-and-error finding out how to get a sink drain to a smaller hose. Thanks! My vintage sink has a garden-hose-sized drain which explains why I didn't understand the purpose of this!
