Post by ladywendolyn on Dec 16, 2018 14:12:50 GMT -8
I’m preparing to finish the inside of my trailer and as some new birch panels have been added I have come to the conclusion that my best bet to endure a consistent finish when I’m done is to strip the existing finish off. My trailer is one of the ones where they added a “milky” product into the shellac or varnish and it’s impossible to match. As this is a long term project where I have done everything as correctly as possible I’ve decided that it’s worth the effort of stripping it as I do not want any regrets when finished.
Have any of you done any stripping of the finish on the interior? What product do you recommend? I know that in theory you can use alcohol on shellac but I have no idea if it’s shellac on there, plus it is the weird milky stuff mixed in. So I need something that will eat through everything. I have a proper respirator for safety with the fumes.
Post by danrhodes on Dec 16, 2018 14:42:14 GMT -8
Post by ladywendolyn on Dec 16, 2018 16:37:15 GMT -8
danrhodes is that the banco scraper in the thread you are suggesting?
Post by danrhodes on Dec 17, 2018 13:29:59 GMT -8
Post by ladywendolyn on Dec 22, 2018 22:24:59 GMT -8
@danrodes did you have to sharpen the scraper when you bought it or were you able to use it as is?
Post by nccamper on Dec 23, 2018 5:49:39 GMT -8
My banco scraper came sharp. It did a good job getting a lot of the polyurethane off but the wood still needed a sanding.
I've never used chemicals on the inside panels but I'd try something less toxic than Jasco. Maybe this...
Post by danrhodes on Dec 23, 2018 7:44:33 GMT -8
They come sharp and are not that tricky to resharpen. Watch a video or two, you simply square the edge with a file, stone or sandpaper, then use a hard metal tool like an old drill bit or nail set to create a burr that does the cutting. I've also used citristrip around the house and recommend covering with plastic to keep it wet and active for longer @danrodes did you have to sharpen the scraper when you bought it or were you able to use it as is?
Post by ladywendolyn on Feb 1, 2019 20:49:09 GMT -8
Thanks @danrodes and nccamper for the info. I’m not sure if we have that brand of stripper here in Canada but I’ll check. Canada is weird... you can walk into a drugstore and get codene without a prescription but we have all sorts of laws to protect the trees! So I’ll buy a couple of those flexible scrapers and get started. I did watch a sharpening video and my response was hmmm... ok order two lol but I may be able to get one of the guys at my Windsor plywood specialty wood store who knows how to sharpen them. Just getting back from a cruise... apparently my hometown Winnipeg Canada hit a record low of -52 degrees celsius while I was away. That’s -61 degrees for you in the USA. Sure makes me glad I have an indoor warehouse to work in!
Post by kirkadie on Feb 2, 2019 20:52:57 GMT -8
-61 degrees.. whoa, no wonder you all don't have palm trees on your beaches.
debranch
Wee Camp
71 Shasta Compact
Post by debranch on Feb 3, 2019 17:29:43 GMT -8
and here I am complaining about having to work outside when its 16 degrees in the morning I don't think I could go outside in the winter up there.
Post by ladywendolyn on Feb 5, 2019 22:01:15 GMT -8
and here I am complaining about having to work outside when its 16 degrees in the morning I don't think I could go outside in the winter up there. Canada in the winter is sort of like Arizona or Texas in the summer. Lots of dashing from house to car...
debranch
Wee Camp
71 Shasta Compact
Post by debranch on Feb 6, 2019 2:31:38 GMT -8
I have been on deployments in the middle east where its to hot the swat, heat doesn't bother me like the cold does. I guess its what you get use to.
