PT
Post by PT on May 12, 2020 20:54:45 GMT -8
Thin sheet aluminum beyond the corrugated stuff. Aluminum L channel on the edges with L brackets at the corners mostly held together with pop rivets. I attached the corrugated to the sheet aluminum with screws/nuts at the points where they meet up.
Best part is that only two double ended hanger bolts & nuts attach it to the trailer and it takes maybe two minutes to put on and remove. Attach a hanger bolt midway up on both sides of the window frame and make corresponding holes in the window guard. Align the holes - get the bolt through and cinch down the nut and it's rock solid.
Post by vikx on May 23, 2020 21:37:43 GMT -8
The Alclad should be beautiful!
PT
Post by PT on Jun 10, 2020 19:12:52 GMT -8
PT
Post by PT on Jun 20, 2020 9:47:14 GMT -8
Post by vikx on Jun 20, 2020 10:15:50 GMT -8
It's looking very good! Don't forget to raise the roof vent before laying the new roof. That will prevent a "dip" around the vent...
Post by nccamper on Jun 20, 2020 10:52:40 GMT -8
The construction of your camper is really interesting. Almost like they were designing without a historic guide. To a lesser degree, I thought this about our Forester. Being made by a boat company in the off season, they over-built everything because they weren't starting with past construction guidelines/designs in mind.
PT
Post by PT on Jun 24, 2020 9:52:39 GMT -8
Uh-Oh. Stuff's gettin' serious now...
aries
Post by aries on Jun 24, 2020 12:24:09 GMT -8
Nice,,and not even damaged,,all eyes are following you,,pics plz😬
PT
Post by PT on Jun 25, 2020 20:51:19 GMT -8
Post by vikx on Jun 25, 2020 21:33:27 GMT -8
Don't forget a thin layer of gutter seal might help in areas like this.
Post by Teachndad on Jun 26, 2020 6:38:20 GMT -8
Hi Allen,
I have been away for a while and just got caught up.
I know I have said it before, but your pioneering work on the Holiday House is short of amazing. You are tenacious, and persevere. You are also well skilled for this project and I admire you. I think some folks could have easily gotten in over their heads.
The trailer went to a good home when you found it.
Touche'
Post by mobiltec on Jul 3, 2020 18:28:06 GMT -8
Do like I do and forget the butted joints and just do a fold over with J rail. The 56 Shasta was like that with the top being fold ever and the lower half being butted. I just added some new skin and did the fold over on the entire thing.
PT
Post by PT on Jul 5, 2020 12:24:03 GMT -8
Thanks Larry -
I've contemplated going with foldovers in some areas that did not originally have them and will be taking a close look at making them work. I can definitely do it down the rear edges but that corner in my photo is not perfectly supported by the wood under it so trying to bash a foldover there will be challenging... Will need to get creative :-)
PT
Post by PT on Jul 5, 2020 13:12:07 GMT -8
